200 miles on one tank of gas
ok maybe im just a bit dizzy but is there a way to get a digital display on the RT ? all I have is the analog :( I want digital bars darnit !!! I feel left out
Disconnect the wires to both analog gauges and the display will revert to the digital gauges.
i was shocked ! Hubby and i did a run from Murray Ky to Houston Tx on one tank I was able to get 43 mpg! Never got that again but believe me i was doing the happy dance lol. Now that being said it was in the middle of the night no traffic no stops ave 65 mph. He always gets better milage when he is following me as well.:roflblack:
You must weigh 100 lbs and had a 50mph tailwind.. Lol
This is where I get lost, I can only put in a max of about 3.2 gallons when the light goes on. That means the tank should still have about 2.8 gallons (nearly half full), allowing .6 gallons for empty space when the tank is "filled." My mind just can't seem to accept that the second half of the tank is running on empty, but all the numbers indicate that this is the case.
Thoughts?
Similar here. Light goes on at 110 miles or so. Then takes 3.X gals. I have not yet figured out the range...seems early for the low fuel light to activate.
gas mileage
best ive done is 180 per tank and was bout of vapors....middle of summer 89 octane...used cruise control alot. remember when you set your cruise your computer knows exactly how much fuel is needed to maintain speed..i use it all the time and get great gas milage. :yes:easy start off the line less you have an idiot next to you..drive safe
milage
Just got back from a trip to Montana. Got 31.8 from Spokane WA. to Clark Fork. That was with 1300 miles on byke and rider with passenger for most of it. I ride very conservatively. hoping it stays around there.
