Dan_Ashley
For post # 29:I posted it because it became apparent from their responses that people on this board were not familiar with the capabilities of a wing. Regardless of what you think of the rider's style or actions, it does show what a wing is possible of. If you want to see me riding I posted a small portion of it in post#29.
Turn positioning much better. Still needs a little more focus though. Remember all three: Outside-inside-outside. All 3. Also, it appeared that on at least two occasions the brakes were applied after setting the line for the curve. This can cause major loss of traction--especially if you are using the harder car tires instead of the stickier, softer motorcycle tires. Car tires last longer, but they do not provide either as large a contact patch, nor are they as sticky as motorcycle tires that have been properly warmed up.
I suggest you practice cone to cone swerving in an unused parking lot. This will help a lot in both road positioning and in establising an entry speed for corners, so you won't have to brake in the turn, and won't go wide. Going wide is a big danger-- it is responsible for about 40% of motorcycle, single vehicle crashes, another 40% being braking too hard in a turn.
Going too hot into turns (the combination of the two issues aforementioned), whether being surprised by road conditions or not, causes about 80% of single vehicle motorcycle fatalities.
Of course this statistic is confounded by the turn-based run-off-the-road fatalities where the motorcyclist collided with a fixed object. There is absolutely no clarity in the National Highway Transportation Safety Agency data on these two issues. It appears that the collision with fixed object data and the speed too high for a turn data is originated by the cop who initially writes the report, and there is no standardized training or instruction for which option the officer should choose.
in short too much speed, or braking in turns, especially on car tires, decreases the probability that the rider will collect social security.
So, go practice. The video of your driving is much better than that other guy....that other guy should stay away from motorcycles.
