12v plug
ingramsail
Want to install a 12v plug in a 2010 RSS, the fuse box has a 3amp space but can not find the line connection at the end. Does anyone know where the wire feed goes to? I can find the wire feed coming out of fuse box but loose it in the wiring loom.
There are two different 3 amp accessory circuits on the RS. The switched accessory harness (provided to feed an optional 12V outlet in the front trunk) is tied in the center near the steering and trunk latch. The unswitched accessory harness is tied near the left front upper suspension support. Both are most easily accessed by removing the trunk.
Have to agree..!!
:agree: the one for the frunk outlet comes with the rubber boot and terminals attached. You don't have much cable if you place the outlet anywhere else. Good luck..!! :thumbup:
