Wildrice
PN:204-26-008 Installation instruction illustrate locating items in the front trunk. The illustrations must be for something other than the F3's. There is no pop-out grommet in the inner or insertable trunk tub.
I do see the grommet & Accessory wires under the passenger seat. Not the best location --I'd need to get longer wires for any USB accessory or 12 v round input connector.
Has anyone found a front location to mount the 12v outlet.
I installed the RH Aux light--plugged it into the adjacent connector; Removed the pop-out gromet on the right side of the ignition swith & plugged the push button lamp switch into the available connector. Started engine--push aux light button & No light--illumination. RH fuse Box fuse #10 is good. Was there something else I needed to connect. Haven't used meter to check volts yet--just looking for quick easy answer- That quick easy answer on the Spyder F3 make me chuckle-well the windshield-saddle bags, exhaust changes, seats were fairly straight forward.
Thank you for your time & any assistance.
Darrell
Darrell
