12V Accessory Outlet
Studybaker Bob
I noticed in shop talk a thread regarding the 12V Accessory Outlet, & in checking my spyder, noticed the installing genius mechanic did not check his work and install the fuse for the 12V Accessory outlet. So, I checked my 7 pages of instruction sheet to find out where the fuse is supposed to go. The 7 pagesof instruction sheets did not show or mention the fuse. I then checked my $135.00, 578 page CAN-AM spyder shop manual and found 1 empty fuse spot on the rear fuse box on page 385 and 2 empty fuse spots on the front fuse box on page 385 & 386. Now, I would like to know what fuse box and what amp fuse do I use to get 12V power to my 12V accessory outlet so I can plug in my electric vest?? I angers us to know that we paid the genius mechanic at St Boni Motorsport in St Bonifacius, MN for about 1 hour of work at about $100.00 to install the 12V accessory outlet. We believe it is fair to voice negatives about bad dealerships & good to praise good dealerships, so, a good shout out to Pete Hoff, service manager at Tousley Motorsport in white Bear Lake, MN.
picture.php
If you are referring to the power point in the front compartment, it may not be suitable for an electric jacket liner. I think it only has an 18 gauge wire for the feed (I could be wrong about this). I installed a separate power point below the instrument cluster for the electric jacket liner. It feeds from the Evoluzione power bus with a 14 gauge wire. There is another power point for the Garmin 550. I have had the opportunity to use both of these quite extensively and I am pleased with the results.
:agree: The switched accessory circuit is only wired with 20 ga. wire, and is rated only for a 3 amp fuse. I suspect you could get by with 5 amps for a short while, but even that would be a stretch over a long ride. It might handle the 4.5 amps for a heated vest, but it might not handle it for long without wiring damage, and it sure shouldn't be equipped with a larger fuse, as would be normal with the heated gear harness. You will not be able to add heated gloves or any other accessories to the circuit, either, or use a heated jacket instead of the vest. I recommend using the switched accesory circuit to trigger a relay to power an auxiliary fusebox like the Evoluzione Powerbus or the CenTech fusebox.
