3 Wheel Addict
Did I not read somewhere you can swap a fuse and make that plug live all the time? How bout the one in the frunk can it be made live all the time to?
First, I would check the fuse for myself. Dealers make mistakes. Second, in light of the fact that your dealer has not contacted BRP, I would contact BRP Customer Care and open a case file for the problem. They can then inform your dealer on how to address the issue. Let us know how things turn out.I don't know what is wrong with my 2013 RT-S. When the latest service bulletin was being done I asked the tech to move the fuse in #6 to #7, since he was in the area with the fuse box upgrade. Told me that the fuse was already in #7 and the #6 fuse spot wasn't connected to anything. The 12 volt outlet is only hot when the key is turned on and the fuse is in the #7 spot. I have no idea what is going on. The service guy said he would call BRP but I doubt this will get done. Checked 1 wk later and he hadn't called yet.
Did you follow up my questions in the other thread about this? http://www.spyderlovers.com/forums/showthread.php?62970-Charger-pigtail&p=757225#post757225I don't know what is wrong with my 2013 RT-S. When the latest service bulletin was being done I asked the tech to move the fuse in #6 to #7, since he was in the area with the fuse box upgrade. Told me that the fuse was already in #7 and the #6 fuse spot wasn't connected to anything. The 12 volt outlet is only hot when the key is turned on and the fuse is in the #7 spot. I have no idea what is going on. The service guy said he would call BRP but I doubt this will get done. Checked 1 wk later and he hadn't called yet.
It is most likely in the connector into which the rear light harness plugs into. One would have to add one or two pins to the connector, or tap into the 12 volt line ahead of the connector. If anyone really wants to know I can look on the wiring diagrams to find it.For ST folks, since they share the same wiring harness as the RT there should be an unused 12v accessories source in the tail that could be used for Farkles.
I have had the #6 fuse moved to the #7 so the power outlet in the trunk is powered on with the key in the off position on my 2014 Limited. This makes it very easy to plug in the trickle charger.
Here you are. The only real difference to look at them are the fuse and relay positions that are not used.Thanks! :thumbup:
Somebody will have to put their "eyes on the prize", and let us know what's under there.![]()
Not unless you have something plugged into it that stays live all the time. But the battery will run down in relatively short order anyway. There's enough stuff in the system that stays hot the battery will run down in a month's time even with the key turned off.Wll it run down the battery?
