NuttyBuckeye
Some observations:
1. Tracking well thus far so alignment is good. I’ll keep an eye on tire wear patterns.
2. Quirk? I started the bike up while standing beside it and got the exclamation point/limp mode message. I shut it down and then sat on seat...normal start. I did it again (standing beside) another day and realized I did not press the start button squarely...kind of off center. Spyder doesn’t like that.
3. Installed “missing” belt guard. Straight forward install. I trimmed the areas that fit around the brackets (to clear the welds). Fit check, then cut the protective film in the center and pulled back each side a bit. Positioned the guard in center first, then worked each side a bit at a time by pulling film away as I pressed the guard on. Test rode to make sure nothing was hitting.
4. At highway speeds (65-70), I hear/feel slight vibration. Comes and goes when varying those top speeds. No biggie for now.
5. I think I finally got BRP Connect to work, will test it out tomorrow.
6. Next up in upgrades is a decent sounding horn.
7. Having hella good time with this awesome machine.
