Results 1 to 25 of 25
Thread: Torx
    Oct 2013
    rome new york
    Default Torx
    Anyone know the size of Torx on floor boards for F3 Limited.
    And is there a better choice to put in there than a torx bolt.
    TIA
    Mar 2017
    Desperately hating Torx. I am on a mission to eliminate all Torx (star) screws on my F3. I am using m5 x .8 x 20mm stainless black oxide pan head phillips screws. I got them on Amazon but you might be able to find them elsewhere. I bought 50 of them for $13 on Amazon.
    https://smile.amazon.com/gp/product/...?ie=UTF8&psc=1
    Nov 2012
    North Las Vegas, NV
    Quote Originally Posted by bmccaffrey View Post
    TIA
    If you mean the ones to move the floorboards, they aren't Torx. They are 5mm Allen.
    2016 F3 Limited
    2019 Ryker Rally
    2014 Suzuki V Strom 650
    2020 CSC TT 250
    Mar 2019
    lakewood ranch fl
    What are the size of the bolts holding the wind screen on a 2019 F3 Limited , want to change the chrome out for black ,
    Durham,Maine
    Quote Originally Posted by Rattlebars View Post
    To each his own, but a torx head is a more positive connection as far as tool to screw than a Philips head!! I find that they strip easyer! Just my two cents Now if you are trying to loosen a Allen head screw with a torx bit well that don't work so well!!! That has been some thing that's driven me nuts with BRP, mixing up all these fasteners threw out the bike! Allen, torx ,Philips, keep them the same for god sake!!
    2012 RTL , Pearl
    Active Member LifeLongRider's Avatar
    Aug 2018
    Florida
    anyone know the size of torx on floor boards for f3 limited.
    Tia
    There are no torx used on the f3 ltd floorboards, they're all allen heads (at least not on my 2019).
    2019 F3 Limited
    2019 F3 Limited , Oxford Blue
    Clinton, MS
    They are not thinking about the end user, only what works on the assembly line.
    Mar 2013
    Clarksville TN
    I'm thinking about replacing all the Phillips with Torx. The Torx give a much more positive connection to the tool.
    2015 F3 (wife's)
    2014 Indian Vintage
    2019 AMG C43 cabrio
    1966 LS1 Corvette restomod
    1956 Corvette survivor (wife's)
    1941 Chevy hotrod truck
    2024 Corvette ERAY
    Torx is to Hex (Allen) what Phillips is to Flat Blade.
    When you consider that the ultimate purpose of a machined bolt or screw head is to resist stripping and transfer as much torque energy to the fastener as possible. The undisputed fact is that Torx is superior in every way to a Hex or Allen head. Personal preference aside. It's just a matter of physics. One of the issues I've seen many times is someone using an Allen wrench on a Torx. Or vise-versa. This will definitely give you grief. But this is not the fault of the design.
    Here is a short article which outlines the benefits of the Torx. I don't have a dog in this race. And I am all for each person using what they prefer. After all, it is your ride. But go into it with all the facts.
    http://rtstools.com/why-torx-bolts-a...han-hex-bolts/
    Lemoore, Ca
    Too many can't figure out Torx or Allen heads. That's why they strip them out. Torx and Allen work great. Put your glasses on and look at the differences.
    Mar 2017
    If your assumption is that I'm using the wrong tool, I'm not. I agree that the inconsistent application by BRP is... well... Thanks for the basic elementary but unnecessary education. If the torx they used would react to a magnet, I would have left them. However, they don't because they are made of some alien alloy. I use an impact driver to work on my bikes and never have a problem. But after dropping several alien torx into the bowels of the Spyder I made the change. They are M5 x .8. After 30 years in the auto industry... Anyway. putting torx that is immune to magnetism IN A RECESS is less than ideal, by polite verbiage. Engineers should be forced to use what they design 10 times daily for a year before the design becomes final. The mudguard on the rear of the F3T is a good example of insanity. The only thing a torx bit is good for is to get a stripped allen head out.
    Mar 2017
    Quote Originally Posted by spyderbear View Post
    M5 x .8 x 20
    Mar 2017
    The bolts I replace are low torque. Again, no magnet will hold the ones on the body panels. I often wonder what magical device the assembler use on the line.
    ….. However there is reason they do this ….. If you need a T30 Torx bolt ….. where do you get it …. from a dealer that sells OEM bolts ….. How much do you pay for it ???? …. $3 - $4 - $5 ( I've never bought any ) … What do you think BRP paid for it $ .03 - $.04 - $.05 ….. Now you know why they don't care how many you lose !!!! ...………….. Mike
    I agree that mixing up the drive tools needed is not good engineering. I always wonder if low bid gets the nod more than it should. I also agree that Torx, though superior in the ways mentioned, is not necessary in low torque applications. Using a non-ferrous metal keeps rust out of the picture. This may be a reason for the bolts used by BRP.
    Durham,Maine
    Like I said, to each his own
    2012 RTL , Pearl
    Active Member wingit3611's Avatar
    Dec 2016
    Louisville, KY 40214
    Quote "Using a non-ferrous metal keeps rust out of the picture. This may be a reason for the bolts used by BRP." Remember this is a "snow sled" with wheels. Got to watch out for rust in all that wet out doors snow.
    Can Am 2013 RTL SE5
    Linden, CA
    TIA
    Just about anything but try and get stainless grade 8
    Florida Swamp
    You can buy a whole set of Torx Bits for about $10 or a set of Torx Sockets for $15. Why would anybody buy just one Torx tool? You gonna need a different size one day next week.
    2019 F3-S , Black & Silver
    Very Active Member AeroPilot's Avatar
    Nov 2012
    Pueblo Colorado
    When dealing with brand new "Lok-tited" bolts and screws its always nice to have a new Torx bit to grip better. I found a 2 pack of Torx 30 bits at Lowes the other day for a little more than $3.
    I'll keep one in the tool kit on the RT and add the other to the tool chest. It also seems that the more I wrench on these things, most of the bolts don't really have to be as tight as they tend get wrenched on by techs at the dealerships... or even the oil drain plugs on the car for that matter. Usually snug is good!IMG_0601[1].jpg
    07 Shadows, Aero, Spirit gone but not forgotten
    03 Harley Sportster, 07 RK moved on
    11 RT- 76,000 mi, 15 RT-S- 44,000 mi, traded for current 15 base RT and 16 F3T
    2015 RT , OEM Black Gloss
    Florida Swamp
    When dealing with the Locktite bolts on anything, adjust a butane torch to a blue tip and hold it on the head of the bolt for about a minute and you can back the bolt out just like it never had any Locktite on it. Ain't gotta be glowing red or even hot enough to burn the paint around the bolt. Just get it hot enough to melt the Locktite.
    Also works to heat up rusted nuts.
    Mar 2017
    Also works to heat up rusted nuts.[/QUOTE]
    Would not recommend on a recessed body panel.
    Quote Originally Posted by wingit3611 View Post
    I have many Phillips on my quads that respond to a magnet and made of a non-rusting alloy. Being on my quads, they see lots more corrosives than on my Spyder. I'm sure they also think the cute little coneheads are a plus!
    Florida Swamp
    You have to use common sense with the heat. None of the body panel fasteners on mine have had Locktite on them. I changed out all the little button head hex fasteners for socket hex cap screws.
    True, you can get low nickle stainless which is less prone to rust and will stick to a magnet. I just don't think that sticking to a magnet is part of BRP's check-off list.
    Apr 2015
    Green Bay, WI
    Quote Originally Posted by petegtsv10 View Post
    I find the torx to collect head dirt limiting the depth of the tool. I've replaced most of mine with allen head screws & bolts. No problems now.
