Parking Brake Fault
Trying to fix this.
Repalaced #3 fuse 25amp in front trunk. Took the key and walked away for 15 minutes, twice, the brake cable looks fine in the rear pulley.
Any suggestions?
Teddys favorite human
Motorbike Professor
Does the parking brake work? If not, the cable probably came off the (front) drum. If the brake does work, it could also be due to the cable not releasing all the way. Some cleaning and lubrication can help there. The brake cable couls also just be out of adjustment. There are other possibilities, too, depending on what the fault code says.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
parking brake does not work
Parking brake does not work...
The brake cable is engaged with the rear pulley and from what I can see it is engaged on the front pulley as well...can't see the front pulley as well.
You'll have to remove the side tupperware to view the front pully
Originally Posted by Ride Master
Parking brake does not work...The brake cable is engaged with the rear pulley and from what I can see it is engaged on the front pulley as well...can't see the front pulley as well.
The front pully has a bad habbit of popping out of its holder & I believe there is a recall that covers this, or the spring one. But its very easy to see if this is the problem, if you pull the middle side panel on the right side off. That however, requires the removal of other panels as well to get to remove the middle panel
pushing for codes
Pushed all three 4 times...get blank screen...all three at the same time with the key on
Originally Posted by CyncySpyder
With the key on, push the MODE, SET & TURN SIGNAL CANCEL (push in) BUTTON, ALL 3 AT THE SAME TIME
If you do it correctly, you should see something like the above, but with your particular fault codes
Thanks. I think I need some training on removing the side panels. I watched Lamont's video...what a process it is.
Either its not throwing any codes, or maybe, try starting the Spyder and then try the same process. Last time I needed to use it, the Spyder was running. Not sure if it has to be or not, but I'm thinking if you got a blank screen, you did it right and its just not throwing any codes. The next step then, would be to either take off the side tupperware and inspect the front pulley or its dealer time sorry
