Results 1 to 13 of 13
    Active Member RangerRick's Avatar
    Jul 2022
    Coos Bay, Oregon
    Default Any way to put Saddlebags on a 2013 ST?
    Trying to find, is there any way to put a saddle/saddle bags on the 2013 Spyder ST? Seems like I saw pictures of back in the day a model having 1 bag on the side? Don't know if they mounted to the rear passenger handles, but then how would you keep them off the plastic side panels back there??
    Last edited by Peter Aawen; 06-06-2024 at 06:15 PM. Reason: Expanded title to briefly ask the question... ;-)
    2013 Spyder ST-SE5
    US Army 1971-1973
    Army Guard 1990
    Air Guard 1991-2010
    Oct 2015
    Lynden, WA
    I had a 2013 STS. I found factory saddle bags and mounting frames on Ebay. I'll send pictures of the bike with the bags when/if I find them.
    David C
    2016 F3T
    Battery tender cable
    Rear IPS Pack Rack
    Quote Originally Posted by Haze View Post
    OR look on e-bay for hard or soft bags , they are usually sold with mounting frames .... years ago I bought some from " MUTAZA " .... they looked great for less than $250.00 plus they came with really nice frames ....good luck ...Mike
    Jul 2022
    Coos Bay, Oregon
    OR look on e-bay from hard or soft bags , they are usually sold with mounting frames .... years ago I bought some from " MUTAZA " .... they looked great for less than $250.00 plus they came with really nice frames ....good luck ...Mike
    Thanks for the Information and suggestions I will check it out
    2013 Spyder ST-SE5
    US Army 1971-1973
    Army Guard 1990
    Air Guard 1991-2010
    Active Member fetermel's Avatar
    Jan 2016
    MN.
    Search Mutaza Saddlebags in the threads. I have a post with pictures of how I did it. I installed these on my bike, and they work great. Hope it helps.
    2013 STS , OEM Circuit Yellow
    Jul 2022
    Coos Bay, Oregon
    Quote Originally Posted by fetermel View Post
    Thanks so much for this post. I was able to find yours' and Von Baden's posts and the info on Mutaza Bags, which look like the bags I need
    https://www.mutazu.com/products/muta...ee023a33&_ss=r
    2013 Spyder ST-SE5
    US Army 1971-1973
    Army Guard 1990
    Air Guard 1991-2010
    Jul 2022
    Coos Bay, Oregon
    Quote Originally Posted by RangerRick View Post
    Thanks so much for this post. I was able to find your and Von Badens posts and the Mutaza Bags, which looks like the ones I need
    Just pulled the plug on these.
    https://www.ebay.com/itm/231854436544
    2013 Spyder ST-SE5
    US Army 1971-1973
    Army Guard 1990
    Air Guard 1991-2010
    ... I bought the bags from Mutaza, but at 1/2 that price ... I looked at the bags on that page - 28L - and probably bought those .... No matter .... I did have a concern about the latching mechanism that held the bags to that mounting frame, so to ensure they COULDN"T come off accidently, I drilled a 3/8th inch hole from inside the bag. .... First, I mounted them; and then drilled the hole from inside the bag THROUGH the where it mounts to the frame .... I then put a short 3/8ths of an inch bolt into that hole and welded it to the frame so it would come into the back of that bag... Now I could put a washer and 3/8ths of an inch LOCK-NUT on the bolt, and this would guarantee it could NOT come off accidently. ..... Many years back, when these bags became popular, another member (JimVonBaden) posted a HOW-TO video on some modifications he did to the frame .... I put His name in the SEARCH box and found it .... Good Luck ...Mike
    Jul 2022
    Coos Bay, Oregon
    Yep, stuff is not cheap now days. Lucky for me, they were still available. Finding after market for an 11-year-old machine is getting pretty iffy. I have looked at Von Baden's and Fetermel's posts, which are a great help, as well as your post's
    2013 Spyder ST-SE5
    US Army 1971-1973
    Army Guard 1990
    Air Guard 1991-2010
    Jul 2022
    Coos Bay, Oregon
    Well my bags came today, nice looking BENCH ORNAMENTS, came with no Spyder specific instructions on how to mount the Universal brackets on the Spyder, and to me it's not obvious. So maybe some Day I will figure it out, but not NOW.
    2013 Spyder ST-SE5
    US Army 1971-1973
    Army Guard 1990
    Air Guard 1991-2010
    Jul 2022
    Coos Bay, Oregon
    Well I was able to find JimVonBaden's thread again and copy the pictures he posted, and now I should be able to figure it out.
    2013 Spyder ST-SE5
    US Army 1971-1973
    Army Guard 1990
    Air Guard 1991-2010
    Jul 2022
    Coos Bay, Oregon
    PM'd Jim about something and he responded right back with more pictures, so tonight they're on there, but not wired yet. Thanks again to Jim for the help and to the others who got the ball rolling.
    2013 Spyder ST-SE5
    US Army 1971-1973
    Army Guard 1990
    Air Guard 1991-2010
    Perseverance will get you there ..... consider adding the bolt I mentioned above .... quick release mechanism's can cause issues ..... good luck ....Mike
