How do I put my RT Ltd into Neutral and shut off parking brake alarm?
I’m a new Spyder owner and have a 2023 RT Limited. There are times, like when wanting to check tire pressure, when I want it in Neutral so I can slowly roll it. That means I want the parking brake off. But if I shut the Spyder down with the parking brake off it gives me 20 seconds of screaming at me. How do we shut the bike down, in neutral, with the parking brake off without triggering 20 minutes of misery?
Reason: Expanded title to briefly ask the question... ;-)
That just how it is designed!
![](signaturepics/sigpic41158_6.gif)
Fronts really don't matter for valve stem orientation. I usually note where the rear one is, turn bike on and disengage parking brake and roll it to where I think I'll have access. I usually get it right, you can access the rear one as long as it's in the back 1/4 of the revolution or so. Then put it back in park and turn it off. That's how I do it anyway.
![Quote](images/misc/quote_icon.png) Originally Posted by SpyderMinimalist
My 2020RTL will beep for about 15 seconds, definitely NOT 20 MINUTES!
2020 RTL Chrome, Marsala Red "Non-Directional Tires, Centramatic Balancers"
Front- Kumho KH-16 175/55r15 @17psi, Rear-General Altimax RT-45 215/60r15 @20psi
BaJa Ron Ultra 3 pcs sway bar kit
10W40 Amsoil Synthetic Motorcycle oil
7jurock 25" tinted windscreen w/flip
Frogman Dave's "Signal Button"
If in Doubt, Don't Do It! ![don't know](images/smilies/shrug.gif)
" Pros: Excellent Bug Killer, Cons: Pizz Poor Pothole Dodger"
Ozzie Ozzie Ozzie
2013 RT Ltd Pearl White
Ryde More, Worry Less!
You Can’t! If the brake's not on when bike is turned off, it defaults to alarm for 20 seconds! However, you do not have to be in N to move around; it's easier, yes; but it's not needed just for a few feet of movement with the SE's. There are also a few different threads here on valve stem extensions & alternatives to make tire inflation/checking easier!
2013 STL SE5 BLACK CURRANT
SpyderPop's: LED bumpskid
minispyder dash toy
Lid lox
KradelLock
Pakitrack
FLO (Frunk Lid Organizer)
BRP fog lights, trailer hitch
SENA 20S EVO
When I stop with not wanting the parking brake on, I put my gloves tightly on the dash to somewhat quieten the alarm.
Dean O
Gran Pa Hoon
Founder San Jose BMW
Alamogordo, NM
'20 Spyder F3 L
very simple turn key on release parking brake roll to spot set p brake turn key off always park in neutral
![Quote](images/misc/quote_icon.png) Originally Posted by fatboy
I do as Fatboy describes, all the time, especially when checking rear tire pressure to get the valve stem in a reachable position. Remember, when you roll your Spyder to where you want, engage the parking brake before leaving the machine (whether the key is in the on or off position). Also, for safety while rolling the Spyder around, always be in a position to engage the parking brake in case the Spyder gets away from you.
Current: 2022 RTL SE6 Red Marsala and 2012 622 Trailer Lava Bronze,
Previous: 2014 RTL SE6 Black Currant - 58,746 miles,
2012 RTL SE5 Lava Bronze - 19,675 miles
Although I always do, you don't need to put the Spyder in Neutral before you shut off the engine. The SE transmission will allow you to move the Spyder by hand when it's in 1st or Reverse, it just takes a little more effort than when it's in Neutral. When I pull into the level floor garage, I routinely tap it into N, set the parking brake and turn off the engine. It becomes habit. Since your new to the Y-Game, you'll develop your own routines for everything.
Just remember one thing, don't turn off the ignition when you're off the machine on the left side unless you see the parking brake light flashing on the display.
otherwise be a vulgar brawl.
Cognac 2014 RT-S
If you don't want to hear the alarm when you turn the key off, then don't turn the key off. Just kill the engine with the Kill Switch. How long does it take you to check tire pressures, anyway. (reminds me of an old joke)
Doug
”Freedom is not a loophole”
F4 Customs SWCV, Ultimate, Lidlox, Adjustable Side Vents, Leather Like Grips, SS Grills, Centramatic, Garmin XT2, BajaRon Original Sway Bar w/ Lamonster links, RLS CD w/ baffle, P238
As others have said, shut it off, then just turn the key to on without actually starting the machine. now turn the parking brake off and roll to where you want it. Set the parking brake and turn key off again.
2023 Spyder RT Ltd ![spyder](images/smilies/spyder.gif)
Whenever my Spyder is parked in my garage, it's in neutral and the parking brake is always off. My key stays with it, too. I also use a plastic wheel chock to be safe. I don't think twice about the 20 seconds of beeping.
![](https://www.spyderlovers.com/forums/maps/map.png?states=CA.OR.WA.NV.ID.UT.AZ.MT.WY.CO.NM.ND.SD.NE.KS.OK.TX.MN.IA.MO.AR.LA.WI.IL.MI.IN.KY.TN.MS.OH.WV.AL.ME.NH.VT.MA.RI.CT.NY.NJ.PA.DE.MD.VA.NC.SC.GA.FL)
Yep, that's the answer. At least it works for our two Spyders.
2015 Spyder RT-S (Arion) and 2021 RTL Sea to Sky (charming wife)
Ozzie Ozzie Ozzie
![Quote](images/misc/quote_icon.png) Originally Posted by LongIsland
![Quote](images/misc/quote_icon.png) Originally Posted by GrayRyder
![Quote](images/misc/quote_icon.png) Originally Posted by Arion
For many of us, that's ^^ the simplest solution! ![thumbup](images/smilies/thumbup.gif)
HOWEVER, I'd strongly recommend that you don't do that too often if your bike is parked up for the winter & you're not actively managing the battery's state of charge!! ![Lecturef Smilie](images/smilies/lecturef_smilie.gif)
Why not?? Simple - every time you turn the key on, the system goes thru its 'Start-up' process, which is a noticeable drain on your battery; and once it's started that process, the system keeps everything ON for a while, regardless of if you turn the key off pretty much straight away - it's not 'tens of minutes', but it's certainly long enough to add up to a significant drain on your battery's 'state of charge' over time &/or repetitions!! ![banghead](images/smilies/banghead.gif)
So if you think you might need to move your Spyder more than just a couple of times during your annual lay-up period, then unless you either ACTIVELY manage your battery's state of charge during any extended lay-up (saaayy, more than a couple of weeks... ) and by 'actively', I DON'T mean just connecting it to a tender/maintainer and simply leaving it for a few months; you REALLY will be better off simply turning your bike OFF without setting the park brake and putting up with the few seconds of beeping while it reminds you that you've chosen to do that!! ![Lecturef Smilie](images/smilies/lecturef_smilie.gif)
Simples, really!
Can also get a "FOBO Bike 2" tire pressure monitor set of valve caps, then you just need to look at your phone to check pressures on all tires at once.
2022 Spyder RT Ltd Petrol Metallic
________________________________
![](https://www.spyderlovers.com/forums/maps/map.prov.png?states=ON)
Harrington, Australia
2021 RT Limited
HeliBars Handlebars
Kenda Kanine rear.
![Quote](images/misc/quote_icon.png) Originally Posted by Peter Aawen
Why not?? ![Roll Eyes (Sarcastic)](images/smilies/rolleyes.png) Simple - every time you turn the key on, the system goes thru its ' Start-up' process, which is a noticeable drain on your battery; and once it's started that process, the system keeps everything ON for a while, regardless of if you turn the key off pretty much straight away - it's not 'tens of minutes', but it's certainly long enough to add up to a significant drain on your battery's 'state of charge' over time &/or repetitions!!
So if you think you might need to move your Spyder more than just a couple of times during your annual lay-up period, then unless you either ACTIVELY manage your battery's state of charge during any extended lay-up (saaayy, more than a couple of weeks... ![wink](images/smilies/icon_wink.gif) ) and by 'actively', I DON'T mean just connecting it to a tender/maintainer and simply leaving it for a few months; you REALLY will be better off simply turning your bike OFF without setting the park brake and putting up with the few seconds of beeping while it reminds you that you've chosen to do that!!
Simples, really! ![2thumbs](images/smilies/a18.gif)
As always it seems, good advice. You certainly help keep many of us on the right track. Thanks from one member!
![](signaturepics/sigpic17779_1.gif)
Those who say " I can't" will always be right.
![Quote](images/misc/quote_icon.png) Originally Posted by cruisinTX
I put mine in neutral by making sure I'm 1st gear before I shut it down; then simply hit the reverse paddle without pushing the "R" button down. That will put the tranny in neutral then shut the key off without the parking brake set. Learn to live with the 20 seconds of beeping. I only do this inside the garage so I can move it around more easily which I occasionally need to do from time to time. I never do that anywhere else except on my level concrete garage floor.
I always recommend leaving it in Neutral .... I don't do it this way .... The SE trans. allows you to move the Spyder around without being it neutral ....Mike
Reason: neural... ;-)
Reason: neural ;-)
OP, you can "mute" the sound by at least half if you take the IC off, remove the back cover and apply some tape to the emitter. With the back cover off, reconnect the cable and turn the key on/then off to locate the emitter. I have had my F3S this way for years. I did two or three layers of a metalized tape and it has held up perfectly...
EDIT: I just tuned in to the fact you have an RT, but I "think" the premise is the same...
![](signaturepics/sigpic22819_2.gif)
Chuck
