Results 1 to 20 of 20
    May 2016
    Okotoks,Alberta, Canada
    Default Time for new Brake pads - should I spend the extra & get BRP pads?
    Hey Everyone….
    Going to do my first brake pad change on my 2015 RTS. Should I spend the extra and get the BRP pads? If there are any other thoughts, tips, links, videos, etc. you can give me, that would be great.
    Thx
    Last edited by Peter Aawen; 11-19-2023 at 04:38 PM. Reason: Expanded title to briefly ask the question... ;-)
    Mar 2015
    forrest above Reno, Nv
    I suggest EBC pads from Bajaron or Lamonster. Great pads and great service. Support our forum providers.
    https://www.lamonstergarage.com/high...-2013-present/
    Lew L
    2014 RTS , Circuit Yellow
    Sep 2017
    Durham,Maine
    X2
    2012 RTL , Pearl
    X's -3 .... BRP just charges more for their inferior product ..... same goes for their OIL & filter kits ....good luck ... Mike
    Bossier loUiSiAna
    Before getting started - Also get: some fresh Dot4 fluid, rags/towels, some brake cleaner, maybe some nitrile gloves. (First time can be messy) Ron’s instructions provided with pads simple & accurate.
    Spyder rear caliper instructions from BajaRon
    "Rear pad install
    The rear caliper also serves as the parking brake the rear piston needs to be retracted as the fronts with a C-clamp. However, it is likely that it will not retract far enough to complete the install. You will see 2 holes in the top of this piston for inserting a tool. The rear piston must be turned CLOCKWISE to retract the parking brake system. It is best to clean the rubber piston boot before this step it may take a good deal of force to start the piston turning but should get easier once the piston begins to turn. Turn the piston until it bottoms out.
    2013 STL SE5 BLACK CURRANT
    SpyderPop's: LED bumpskid
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    FLO (Frunk Lid Organizer)
    BRP fog lights, trailer hitch
    SENA 20S EVO
    Sep 2017
    Durham,Maine
    "Rear pad install
    Ok now that you told him how to do the job, what pads would you use?
    2012 RTL , Pearl
    Apr 2020
    Lebanon ohio
    Just call Baja Ron and talk to him before you start before ordering any parts he has a lot of info he 'll tell you I am glad I did !!
    Mar 2015
    SPEEDBLEEDERS
    Lew L
    Bossier loUiSiAna
    Thought self explanatory “ Ron’s instructions provided with pads” guessing could have caps or bold Ron’s my bad, lost with copy paste laziness
    minispyder dash toy
    Lid lox
    KradelLock
    Pakitrack
    SENA 20S EVO
    May 2016
    Thx for the info !! Any thoughts on the pads themselves? Brand ?
    Feb 2012
    Spring City,Utah
    EBC, BajaRon or LaMonster
    Happy TRAils/NSD
    Paul
    2012 RT L
    AMA 25 years Life Member
    TRA
    PGR
    Rhino Riders Plate #83
    Venturers #78
    TOI
    Very Active Member Flamewinger's Avatar
    Aug 2013
    SF Bay Area
    Since Porsche cars have Brembo brakes like our Spyders, I wouldn’t use anything less. OEM have always worked well with no problems. Never had to replace a rotor on 5 Goldwings that all had close to if not over 100k miles. Won’t go cheap on my Spyder either.
    2021 F3 Limited with 10167 miles
    2018 RT-Limited with 19890 miles
    '13 Spyder ST-L with 21k miles
    '04 GL1800 with 91k miles
    '97 GL1500 with 87k miles
    '95 GL1500 with 102k miles
    '89 GL1500 with 96k miles
    '83 GL1100 with 117k miles
    '81 Honda Silverwing with 36k miles
    '79 Kaw 400LTD with 26k miles
    GWRRA - 40yrs - Life Member
    AMA - 42 yrs
    Just remember, if common sense is so common, why do few people have it?
    2021 F3 Ltd , Magna Red
    Jul 2014
    Mint Hill, NC
    Your life is in your hands and right foot. In my book that demands nothing less than EBC fully sintered pads all the way around.
    otherwise be a vulgar brawl.
    Cognac 2014 RT-S
    Very Active Member JKMSPYDER's Avatar
    Dec 2012
    Murphy, NC
    +++ on EBC fully sintered pads. Only way to go.
    2020 F3 Ltd
    Spyderpops Bumpskid
    Spyderpops Brake/Run/Turn Signal LED's
    Lamonster Garage LED Fog Lights and Headlights
    2013 ST-S retired 1/9/16 at 25,061 miles
    2015 F3S sold at 77,565 miles.
    2015 F3-S , BajaRon Plugs Can-Am Red
    May 2016
    Nope …. My bad lol
    Aug 2007
    Greeneville, TN
    Does anyone know what friction compound is used with the OEM Brembo pads on our rides? I've been told they are organic. But I have never confirmed this.
    The pre- Brembo Spyders came with organic pads (except for the original 2008 models, which came with Semi-Metallic).
    Brembo pads come in a number of variations from organic to ceramic. Not sure how many options are available for the Spyder.
    Everything is a trade-off. Each compound has its advantages and disadvantages. The best stopping comes from Semi-Metallic and Fully Sintered. Each having its own drawbacks. Organic is the least expensive compound (usually a Kevlar or similar material). And is typically found on OEM setups. Organic offers the least amount of braking force and longevity. But offer other advantages.
    People worry about rotor wear. The only rotors I've ever replaced on my own or customer's bikes were due to metal on metal from worn out pads, or warpage. Regardless of pad compound. Motorcycle rotors just don't wear out if cared for. You can reduce the chance of warpage by correctly torquing wheels, using compression braking, and not mashing the brake pedal when stopped with hot brakes. Compression braking also has the advantage of keeping you in the correct gear, if needed quickly.
    Jun 2011
    Alamogordo, NM
    Ron, have never heard the term Compression braking. Please explain.
    Dean O
    Gran Pa Hoon
    Founder San Jose BMW
    Alamogordo, NM
    '20 Spyder F3 L
    Mar 2017
    Salisbury,NC
    Quote Originally Posted by old Timer View Post
    thats just letting the engine brake some for you. throttle closed, you will feel the speed start to slow down, with no juice the compression of the engine will start to slow the spyder down a little
    Dec 2013
    Another term for it is Engine braking... at its simplest, just back off on the throttle & let the driveline & gearbox slow the vehicle as it forces the pistons to keep turning against the engine's compression without the throttle supplying fuel to make power.
    Or, as Ron suggested, changing down thru the gears as you slow - if you want to 'brake' harder while engine braking, you can even change down a gear or two, matching the engine revs to gear selection & road speed as you do that tho so that you don't slow the drive wheel/s speed so much/so rapidly that it breaks traction; then back right off on the throttle again, letting the s/lower gear selection add to the slowing effort above & beyond that provided by only working against the compression ratio with no fuel to burn.
    2013 RT Ltd Pearl White
    Ryde More, Worry Less!
    Aug 2007
    Greeneville, TN
    Thank you Woodaddict and Peter Aawen for clearing this up for everyone. I should have used the term, Engine Braking, as you did. I need all the help I can get!
