Results 1 to 21 of 21
    Aug 2019
    Stoughton, WI
    Default SpyderExtras F3 Front Grille Guard users
    Just inquiring to see if any F3 owner/members here have this grill guard installed? Yeah .. it's kinda pricey, but the heart wants what the heart wants Just curious about thoughts/opinions from any owners. Thx
    2019 F3-S SE6 Monolith Black
    Comfort: Madstad 14" dark gray - 20" light gray windshields/Seth Laam seat/Homemade floorboards-highway pegs/+4 and +5 linkage/Attitude bars/Heated grips/Big Bike rider backrest
    Ride and Handling: Spyder Extras sway bar/Vredestein Q5 front tires/Cooper CS5 Ultra rear tire/Two Up shock/Laser aligned/15" Widow PPA wheels
    Performance: DynoJet PV3 (custom mapped by Fuel Moto)/K&N air filter/Baldwin cat delete pipe/Lamonster belt roller/Pedal Commander/EBC HH brake pads
    Convenience: Shad detachable luggage/Top Cuff w/handlebar mirrors/Garmin Zumo XT GPS/Lamonster Packrack-Kappa 56L top case
    Safety/Protection: H4 LED headlights/Aux rear LED lights/TricLED driving lights/TricLED run-brake-turn rear light/Frunk lip LED light strip/Spyder Extras bumper guard grill
    2019 F3-S , Monolith black
    aka: akspyderman ARtraveler's Avatar
    NW Arkansas
    I do like the looks of it. I don't have one myself. Now it will really look like a Dodge truck.
    Currently Owned: 2019 F3 Limited, 2020 F3 Limited, 2015 Vulcan 900 LTD
    Previously : 2008 GS-SM5 (silver), 2009 RS-SE5 (red), 2010 RT-S Premier Editon #474 (black) 2011 RT A&C SE5 (magnesium) 2014 RTS-SE6 (yellow). 7 Spyders, 12 years, 175,500 miles
    2019 F3L , Phoenix Orange
    Aug 2019
    Stoughton, WI
    Ha .. Yup. Having a black F3S, I think it'll look bad azz
    Bossier loUiSiAna
    Gill guard or push bars? Looks good is it beefy as looks?
    BRP fog lights, trailer hitch & 622 trailer (with its own list: Spyderpops Lighted Rear Bumpskid, LineX protection on sides, led trim lighting amber front& red rear, stand& tongue handle)THX Cruzr Joe!
    (pics in album)
    Aug 2019
    Stoughton, WI
    Deer Bashers ? Hopefully not too heavy. Might have to ramp up the preload to get some height back ...
    Feb 2019
    Portland, Oregon
    All I wanted was something that will lightly touch a concrete wheel stop in a parking lot before the plastic chin bar does. Rivco sells an attractive bumper at a high cost and it's not for F3 bikes. So I made my own out to aluminum bar and shapes, since I can't weld. If I could weld, it would have looked different and made of steel.
    Sep 2009
    Columbus, WI
    I dont think you can use your spyderpops bump skid with it since it has it's own built in skid plate. If you go that way I maybe interested in buying your bumpskid.
    2018 F3 Limited , Oxford Blue
    Feb 2019
    Portland, Oregon
    Quote Originally Posted by JP58 View Post
    If you ae talking to me, I don't have a bumpskid. But the two 1/4 X 1" aluminum bars that the bumper is attached to will act as a skid.
    Sep 2009
    Columbus, WI
    I was referring to Troop. He lives near me and has the bumpskid on his F3
    Aug 2019
    Stoughton, WI
    PM sent. Sounds good JP.
    Aug 2019
    Stoughton, WI
    Ordered
    Aug 2019
    Stoughton, WI
    Arrived today and got it installed. I like it . I'll wait till another day and dial up the preload on the front shocks. This weighs 13#, so it won't hurt. I see some amber lights for it in the future too
    Sep 2009
    Columbus, WI
    Nice!
    May 2019
    Port St. Lucie, Florida
    I like it a lot! The You Tube video of an install looks easy. Is it?
    -Carsong
    2018 F3t
    2018 F3T , Position 5/ full size Matt Black
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by carsong View Post
    Ha ... That's what I thought I drove mine up on tire ramps, which gave ample work room. I found a cardboard box the perfect height to hold the guard up. Weighing approx. 13#, and being a bit wide, it is very hard to hold upright without support. Plus, you don't want it hanging from a single (or double bolt). With the box centered underneath the guard, aligning bolts > bolt holes was MUCH easier. So, the answer is NO without a support, and YES with a support.
    Feb 2020
    N. Wilkesboro, NC
    Looks nice, troop. My only concern would be the (4) (2 on each side) bars that angle back towards the suspension. I can see hitting something easy enough to not damage the front of the bike but just hard enough to allow those (4) bars to contact the suspension. Might do a LOT of damage in an otherwise fairly minor collision.
    Aug 2019
    Stoughton, WI
    Quote Originally Posted by MONK View Post
    The photo is a bit misleading Monk. The end caps of the guards are 12" from the suspension. The guards crashing against the grill would prevent that. I think most damage would occur at the (4) lower mounting bolts. This guard actually has a touch more ground clearance than it did with my SpyderPops bumpskid installed. With the 2019 F3S having the ribs on the underside grill, the bumpskid actually sat 1/2" lower to the ground.
    Aug 2019
    Stoughton, WI
    The grill came with mounts to add more lights
    Feb 2019
    Portland, Oregon
    I see a potential problem; where the oval tubing angles down and is welded to the supports that go under the bike, there is a sharp corner. When hitting a pothole or a sharp dip, that will dig in like a plow. I have already scraped the bottom front edge of my DIY bumper's channel, so I am going to replace it with round or half round material.
    Aug 2019
    Stoughton, WI
    We shall see. This will be approx. 1/2" higher than my Spyder Pops bump skid, as the underside ribs are not an issue to mounting. That did scrape a few times. Won't be riding here in WI for a couple months.
    Sep 2008
    TX
    I like the looks! Having just replaced the two "breakaway supports" on my '15 F3-S, after the bumpskid caught on a RR crossing, I would be wary of any structural function of the guard. There is no metal, other than the frame, anywhere close to the front end. Having a substantial weight cantelevered off the frame where the front suspension attaches may affect steering and handling, too. I'd rather replace the plastic pieces than the frame should I hit something hard.
    We've had/have 2 F3-S and 2 F3źT/L machines, with only one having the bumpskid. Forbme, the bumpskid is not going back on any of our F3 machines.
    pauly1 - SpyderDeb's 'wrench'
    IBA #48220 SS1000 BB1500
