Results 1 to 20 of 20
    Very Active Member BigGuy66's Avatar
    Aug 2016
    North Central Indiana - WInona Lake, IN
    Default I get a strange vibration at higher speeds...
    ... that feels like running over the rumble cuts on the side of the highway. I’m running at 75 on the interstate and if I accelerate when the byke gets to 77 I feel the vibration. I don’t feel anything in the steering so I wonder if it’s engine? Odd vibration. Stops when I back off the throttle. What might this be?
    2019 Spyder RTL. All stock.
    Jim
    Ryde, eat, sleep.... repeat
    2019 Spyder RT Limited
    No new FARKLES yet
    Just passed 600 miles (August 1-2, 2019)
    Variously called Stormtrooper, Pearl, and Goober by wife and various (friends?)
    Active Member RideOn's Avatar
    Sep 2018
    Bakersfield, CA
    I have a new 19 RTL but I haven’t felt the vibration you describe in it. It’s still on break-in miles though.
    My 14 ST had a similar vibration to yours at freeway speeds. I paid very close attention to the source and found the origin was the exhaust system, not tires or drive belt. The fact that it goes away when you back off the throttle would tend to support it being exhaust-related I’d think.
    Good luck!
    “There comes a time in the affairs of men... when we must seize the bull by the tail and face the situation.” - W.C. Fields
    Asphalt Gray/Chrome
    Recently departed:
    2014 Spyder ST SE5
    Steel Black Metallic
    Aug 2018
    Chicago
    Its the belt. you need belt tensioner.
    Apr 2019
    Florida Swamp
    A 2019 should have a factory belt tensioner. My 2019 F3-S had one stock.
    Active Member ozarkryder's Avatar
    Nov 2018
    Anderson Missouri
    Our 2018 RTL does the same thing at about the same MPH. The trikes we ride have a very long belt, and at certain RPM's a vibration is set up that can be felt through the bars and seat. I can make it stop by backing off or adding to the throttle, but when it returns to a steady speed and to that certain RPM the vibration returns. A tensioner dampens the movement on the belt as the trike is ridden so it is not felt or felt very slightly. Vibration can also be caused by a damaged tire or wheel, bad balance, something in the suspension or any cause mentioned in previous (or future) posts.
    2018 Can Am Spyder RT Limited, 2013 Triumph Bonneville T100
    Motorcycle Rights: Charter Life Member AMA, MRF, FORR Local 11 Southwest Missouri, Mid-South MILE organizing committee member
    Feb 2020
    N. Wilkesboro, NC
    Quote Originally Posted by Gwolf View Post
    That's unlikely. My '18 RTL didn't have one and the '20s don't, either.
    Active Member EdMat's Avatar
    Apr 2019
    Clinton, MS
    Nope, not on the 2019 RTL
    Apr 2019
    Florida Swamp
    It must be only on the F3-S.............
    No clue why Can Am would only fix the vibration on one model.
    Sep 2017
    Durham,Maine
    Have you check the tension of your belt lately, maybe it time?
    Jan 2015
    southern WI
    Most likely the drive belt. Very few people get one that doesn't have some amount of vibration around 73mph.
    Aug 2016
    I will get the belt tensioner for my 2019 RTL. I am moderately skilled at some mechanical projects. Can I install the belt tensioner myself? Where can I purchase one? Thanks for the help on this.
    No new FARKLES yet
    Apr 2019
    Clinton, MS
    Try this. http://www.lamonstergarage.com/can-a...ley-lamonster/
    You want the RT Belt Tensioner With Upgrade Roller
    Sep 2017
    Durham,Maine
    Check your belt before you go for the tensioner, try to see if you can live with out it, it will be just another thing to watch and maintain if you put one on! Good Luck, ride more worry less!!!!
    .... also consider this - is the vibration so annoying that you are willing to possibly having to re-place your drive belt ( @ $350.00 ) if the roller on the tensioner fails and ruins that belt ( this has occurred to people on this Forum ) ...... good luck ..... Mike
    Nov 2017
    San Francisco Bay area
    FWIW My 2015 RTL that I bought used also had this problem at 73 mph without fail. I thought it was the belt as well given everyone's experience. When I changed from the stock Kendas on the from the vibration went away.
    So in my case, it had something to do with the tires, I'm not sure what I only know I don't have the problem anymore.
    2015 Pearl White RTL
    Baja Ron Sway Bar
    Russell Day Long Seat
    Strobe Brake Light
    Mirror Mount Turn Signal Indicator
    Aug 2016
    I'm curious about what the damge will be to the belt becasue of the vibration. Won't the vibration cause misalignment, skipping teeth, or something like that? I'm not a mechanic and cetaily not an engineer.
    Jim
    Aug 2016
    Quote Originally Posted by LeftCoast View Post
    (snip) When I changed from the stock Kendas on the from the vibration went away. So in my case, it had something to do with the tires, I'm not sure what I only know I don't have the problem anymore.
    The tires were brand new with only 300 miles (now at 640) at the time of the vibration showing up about 76-77 mph. How did you know to check and replace the tires?
    Jim
    No new FARKLES yet
    Member sandylolee's Avatar
    Oct 2019
    NC
    I have a 2019 Rtl had the same problem. I purchased one of Lamonster’s vibration dampeners now no more vibration. Just remember it’s one more thing to keep a check on for regular maintenance.
    Active Member trong's Avatar
    May 2020
    West Valley City, Utah
    The vibration is an option for former Harley-Davidson owners only.
    Cheers.
    ‘13 Honda CB1100
    ‘13 Spyder RT-L
    Apr 2019
    Florida Swamp
    Quote Originally Posted by trong View Post
    Cheers.
    Not even close........ the front tire of my old hard mount Sportster would jump off the road sitting at a red light idling.
