Results 1 to 11 of 11
    Oct 2013
    rome new york
    Default Trailer for Spyder
    Ok people. Have a little issue.
    Me and my wife would like to take the spyder with us on some trips. Problem being when we bought the Jeep last year i should have gotten the tow package which is not on add on. The Jeep can only do 2000lbs. Would like to go enclosed but probably would have to go to clam shell. Little tires make me nervous with hear issues.
    Any suggestions. Know i can go utility but not much protection for front of spyder.
    TIA
    Feb 2019
    Portland, Oregon
    Check out this company's trailers...........
    http://ironhorsetrailers.com/
    Jul 2018
    Southern Minnesota
    Aluma mc210. Not enclosed, but good rock guard and big tires! Tows like a dream behind the Ridgeline.
    Active Member Boilermaker's Avatar
    Sep 2015
    Muncie, Indiana
    I have an Aluma UT-10 for sale. Has rock guard in front and tool box too. 15" tires (brand new) and Spyder Clamps already installed. Perfect setup for any Spyder. Trailer only weighs 700 lbs. Check additional specs on the Aluma website. Asking $2500.
    2018 RT Limited 10th Anniversary Special
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by Boilermaker View Post
    If I didn't already have an enclosed trailer for my Spyder I'd be all over your trailer at that price.
    2015 RTS SE6 Special Series Red/Black w/Magnesium color front fenders(bought in Nov. 2018 w/9,400 miles)(13,200@9/16/2019)
    All of the following items installed by me:
    Baja Ron's Sway Bar, Baja Ron's Spring Adjusters
    Kumho Ecsta AST KU25 All-Season Tire - 225/50R15 91H (9/14/19)
    Small LED bars above radiator inlets
    Northern Tool Tag-Along trailer
    LED headlight bulbs, LED fog lights (WOW what a difference)
    2" x 2" Road Lights on inside front fenders
    7' x 10' enclosed Cargo trailer
    Garmin 396 LM GPS
    New AGM battery (01/24/2020) with Battery Monitor and APP
    Active Member Wahrsuul's Avatar
    Mar 2019
    Central SC
    If it wasn't so far away, I would too.
    Got to watch the tow ratings - you won't like towing at max capacity. You don't say what model Spyder you have, but most of them are fairly heavy, and when adding 700 lbs+ of trailer you're looking at pushing the limits of your vehicle. That doesn't include anything else you'll put on the trailer for convenience, and you need to watch the tongue weight as that'll add on to the cargo limits of the Jeep.
    Utility trailers tend to be cheaper and if you get a small one they can be lighter. If you're concerned about protection, maybe a towing cover?
    2014 RT-S Orange - LED headlights/driving lights, LED under mirror turns, LED brake/run lights along trunk and saddlebags, LED third brake light, LED turn bulb replacements, Voltmeter, Oil PSI gauge, heated gear connection, BRP backrest, dash Mount USB plug.
    Mar 2015
    Indianapolis, IN
    What Jeep do you have? Is the reduced tow limit because it doesn't have the factory tow package? You can usually determine what the extras were and add them if you are so inclined.
    Joshua
    2012 Victory Ness Vision
    2015 Spyder F3S
    2019 Spyder RT Limited
    Aug 2019
    Jackson, MS
    Post
    Quote Originally Posted by bmccaffrey View Post
    TIA
    Not sure (since you didn't say) which Jeep you have to get the 2000 lb max tow. https://www.towratings.net/make/jeep
    The basic 2 door Wrangler is unchanged and yes remains at that limit, sort of. There are some things you can do to help that number, D or E load tires, Air Bags, and other options like a weight distribution hitch can increase the load safely. Just remember you also have to STOP it, insure the trailer has brakes and you should have no issues. There are loads of lightweight 6x10 enclosed trailers available or ones like Boilermaker or RICZ referred to.
    Best wishes and praying all your rides are safe.
    Bryant, Arkansas
    The heavier Spyders weight slightly over 1,000 lbs.
    Cruzr joe
    [SIZE=4]2018 F3 Limited, BRP Driver Backrest, Spyderpops Lighted Bump Skid, Dual Spyclops Light, Mirror Turn Signals, Laser Alignment, Engine LEDs, Fog Lights With Halo's, Cushion Handgrips, BRT LEDs, and Under Lighting, Lamonster IPS, (with Clock), F4 25" Vented Windshield with Wings, Airhawk "R" Cushions. Position 4 Brake setting, Short reach Handlebars, Dash Mounted Voltmeter and 12 Volt Plug. Set of 3rd pegs. Extended Passenger Seat. Exterior BRP Connect setup, Ultimate Trailer/SIZE]
    Very Active Member Big F's Avatar
    Aug 2012
    Bellevue, NE
    to keep the weight limit issue down yu probably will have to go with an open utility trailer.. I have trailered my Spyder many thousands of miles all over the greater Midwest in an open aluminum trailer from Tractor Supply and nary a problem. they sell them new for less than $2,000.. good luck..
    BIG F
    Nov 2018
    Claremore, Ok.
    Quote Originally Posted by ChapMikeM25 View Post
    My enclosed trailer is 7' x 10' and Spydie barely fits in there.
    Garmin 396 LM GPS
