Page 2 of 2 FirstFirst 12
Results 26 to 44 of 44
  1. #26
    Jan 2019
    Kentucky
    To properly align the beam pattern with LED bulbs you my need to rotate the bulb. The goal is for the horizontal beam pattern to be such that the light moves only straight up and down when toggled between High and Low.
  2. #27
    Active Member Dragracer's Avatar
    Oct 2009
    Lecanto, FL.
    I just installed a pair of the Beamtech's on my 900. I had to loosen the top 2 bolts holding the headlamp assembly in place to be able to wiggle the bulb into the socket. No modifying of any pieces to install them. Will give them a workout this weekend!
    Also ran a usb cord into the glove box and routed it up the left side of the handlebar to power the cell phone.
    Calling an illegal immigrant an undocumented worker, is like calling the corner drug dealer an unlicensed Pharmacist.
  3. #28
    Danbury Connecticut
    I bought a set of headlight and foglight LEDs from Lamonster Garage several years ago.
    I'm very happy with them.
    http://www.lamonstergarage.com/can-a...mbo-lamonster/
    I'm surprised no one else has suggested them first.
    My Gas Tank Is Full; My Bladder Is Empty
    Time To Motor On
    IBA #47122
  4. #29
    Oct 2009
    Lecanto, FL.
    It has been suggested. But we're talking Ryker's here, not Spyders.
  5. #30
    Danbury Connecticut
    Quote Originally Posted by Dragracer View Post
    Can you be sure ???? The OP has photos of an RT in both his signature and his post ??
    And Lamont sells LEDs for Rykers as well.
    Geez. ANother one I have to put on the ignore list. This is getting real tiresome.
    Time To Motor On
    IBA #47122
  6. #31
    Oct 2009
    Lecanto, FL.
  7. #32
    Active Member Markubis's Avatar
    Jan 2018
    NH
    You're putting someone on the ignore list for that?
    I suggest you step back and consider the real reason for having so many people on your ignore list.
  8. #33
    Jan 2018
    NH
    And for the record, Lamonster does sell LEDs for the ryker.
  9. #34
    Danbury Connecticut
    Quote Originally Posted by Markubis View Post
    You're probably right.
    There's been a spate of flame wars here recently.
    I may be too touchy.
    Still, I prefer to stick to the technical aspects when asked a technical question.
    People passing personal judgement outside of the "Off Topic" forum just gets my goat.
    Time To Motor On
    IBA #47122
  10. #35
    Jan 2015
    southern WI
    Take it easy everyone. No reason for ignoring anyone.....I do have an RT in my avatar/signature, but this is a Ryker Shop Talk section and topic about LEDs for my wife's Ryker. Its all good. I ordered LED's on Amazon and saved a bunch of money, and very happy with them in the Ryker
  11. #36
    Houston
    Quote Originally Posted by Mazo EMS2 View Post
    Enjoy them while they last. When the burn out (and they most likely will) suggest going with the ones from Lamont. There is a reason they are more expensive with the power supplies in the lines to protect the LED elements from the electrical noise and voltages on the Ryker/Spyder. Most conventional LED replacements do not hold up well in this service.
    Blue Flame Spyder F3-S
  12. #37
    Jan 2015
    southern WI
    So, by this you're saying that Lamont makes his own LED bulbs...? Not likely. It is likely that he purchases them from someone and re-sells them....much like many other businesses do. That's fine by me, after all he's gotta make money. I didn't specify how much I spent, nor the brand that I bought. So why assume that I don't have the same bulbs that Lamont sells? Don't get me wrong, I love the stuff that Lamont designs and sells on his own, but I don't see him and Jacob and Joan sitting in the shop making LED bulbs.....It's all good....
  13. #38
    Houston
    He has them made to spec for Spyders. They are custom manufactured for Lamonster Garage, not purchased and resold. The charging voltage on the Spyders is considerably higher than most automobiles, near 15 volts at times. Has caused a good deal of trouble for a number of LED products. Then there is the fan that does not hold up well in the Spyder installations.
    No, his are not the same as the ones you bought on Amazon and why I highly recommend fit for purpose units. They are not that much more than the quality generics.
  14. #39
    Kansas
    My BeamTech H4 LED's bought off of Amazon have no fan and last I heard we were talking about Ryker's not Spyder's
  15. #40
    Houston
    Ryker or Spyder, do you really believe one is easier on the lamps than the other? Use whatever you want. I was just recommending a high quality product that has a long and known track record in these bikes as they were designed for the specific application. If you hare happy with generics then fine. Some folks value their time, especially if they are paying a tech to install them.
  16. #41
    Kansas
    I guess if I had the cash to have someone else add accessories to my Ryker I guess I would have the cash for the better LED's. But I'm a frugal guy and would rather work on my own stuff than pay someone to do it. After all, that's how I justify the work shop full of tools to my wife. No way in hell would I pay someone to install headlights. After the sway bar install, I might pay for that labor next time. What a pain in the pootsky that was.
  17. #42
    Jun 2019
    Florida
    I just received a set of Beamtech LEDs from Amazon, which has been recommended earlier on here and I have one question. It's probably something simple that I should know, but getting within weeks of '70yrs I find myself puzzling over things that I used to grasp easily. What is the difference between the S1-H4(HXR) and the S1-H4(VHS)? Mine are HXR and the ones used on Youtube by one person has the VHS on the label. Does it have something to do with the color or watts? Sorry if this seems kind of lame, but I though it might be good to know BEFORE I install them.
    I am also getting ready to replace my handlbar and grips, but that is for another thread.
  18. #43
    Active Member poli's Avatar
    Feb 2019
    East Texas
    Quote Originally Posted by MDLNB View Post
    I'm not sure about the letters but I got mine from Amazon about 4 months ago and love them. Still haven't made up my mind whether they are actually brighter than my original halogens or the white light they put out just makes everything look brighter. Any rate, install them and enjoy.
    Spyder RTS my traveling ride
    Ryker Rally modified for dual sport duty
    Yamaha Bolt C Spec my cruiser
    Honda Grom heavily modified for dual sport duty
  19. #44
    Jun 2019
    Florida
    I installed the Beamtech H4's and I have to tell you that it became a bit more involved than I thought it would be. The base on the Beamtech H4 is wider and the rubber boot becomes a bit more cumbersome in the tight area behind the headlights. I ended up having to remove the headlights to install the new bulbs. I still think that I may have to go back and see if I got the right ring locked completely. The light seems to project a bit off on the right. I won't be driving much at night, but I still think the whiter lights of LEDs looks better, whether or not it produces more light than the OEM bulbs. These bulbs do NOT have the rear fan on them, and I like that aspect. I do not see how the ones with the fans would work very well with that large bulky rubber boot covering the base of the bulb. Seems like it would defeat the purpose of the cooling fan to cover it.
