Page 3 of 3 FirstFirst 123
Results 51 to 72 of 72
  1. #51
    SoFlo
    It seems that the scoop kit based on the fires associated with the 2013 RT models get varied degrees of complete installation.
    The two externally visible scoops do force cool air under the bodywork. However, to properly install the scoop kit, the two acoustic panels are removed allowing even better airflow to the glovebox area.
    The complete scoop kit includes two steel supports. By the original design, the two acoustic panels served two functions, most important is they are the supporting structure for the entire upper bodywork. This is why the steel supports must be installed, to support the upper bodywork.
    Realize also, when stationary, say in traffic, you no longer have the double wall of both acoustic panel and the outer bodywork.
    For comparison, we live in SoFlo, and it gets really hot. I never installed the scoop kit on our 2014 RTS, but we have run the adjustable deflectors since the Spyder was almost new. Kind of nice being able to direct airflow towards the back seat.
  2. #52
    Jan 2024
    Texas
    My research shows that they had eliminated the acoustic panels by my 2019, so that's not in play. I also don't recall seeing anything like that. I've got some sticky heat insulation on order and am going to attempt to redo the tupperware backing foam with it where I can. I will also see if I can fashion a way to insulate the glovebox, or at least keep the heat in the bottom portion of the bike.
    2019 Spyder RT Ltd. Bought in Jan 2024. Can-Am states only.
    Slingmods USB and QuadLock phone mount with vibration dampener | Highway pegs
    Rear GENERAL ALTIMAX RT45 SL 225/60R-15 tire | Drink2Go front/rear Cupholders
    3D printed Turn Signal/Shifter caps | KOTT Grill covers
    LED Headlights | LED Foglights | High Mount Trunk brake/turn lights with brake strobe
    Pedal Box+ w/BT | Show Chrome gas shock for rear trunk
    Foam Grips | Red Rim Covers
    VIOFO MT1 Front/Rear Dash Cam system | Upper Radiator Exhaust Block (SpyderPops)
    ShowChrome Heavy Duty seat shock | RLS Cat/Primary Muffler Delete
    BRP Intake Air vents
  3. #53
    Mar 2017
    Salisbury,NC
    Quote Originally Posted by Allen42 View Post
    I do recall seeing a thread where someone had insulated the top half of their bike, including under the glove box, but cannot find it now.
    there are pcs of styrofoam under the glove box already. take off the outer plastic, and feel under another covering and they are there. 2019 is same style as my 2015. best idea is to get some baker air wings to bring in the air, which are not made anymore, you would have to find used. the 1330cc is not bad for heat displacement. HOT days will be HOT
  4. #54
    Jan 2024
    Texas
    Quote Originally Posted by Woodaddict View Post
    That's fair, it has been hovering around 100 F lately. But I'm tired of our SPF chapstick completely melting in there, and the part of the seat in front of my add-on seat cushion being almost "burn your hands" hot. Even my ignition key gets pretty damned hot to the touch. I first though it must just be the sun beating down on these, but when I lift the seat for fuel stops, the raised metal square section running down the middle under the seat is pretty close to "burn your hands" hot too.
    It dropped into a cloudy high 80s today, so I'm going for a ride after work to re-assess how much is the environment, and how much is the engine.
  5. #55
    Bowling Green KY
    hi could you send me the pdf allso? Thank you, Chip
  6. #56
    Jan 2024
    Texas
    I found a dealer that supposedly still has a few of these for $84 + tax + $5 shipping sitting on their shelves. There was some confusion, as his system showed part 219800388 as "RT Vent Kit", but then loaded it up as "fender flares" when he tried to order it from his warehouse. I've got one on the way, and will let you know if it's the real deal or not. PM me if interested in where I found it. But all the dealers have a global inventory search, so my local dealer told me who to call.
  7. #57
    SoFlo
    Seems you have a plan that is in place for your 2019.
    Kind of a bummer your 2019 does not have acoustic panels since they are effective to keep the outer bodypanels where your inner thigh touches cooler and are a form of double insulated.
    No part of our bodywork, key switch etc gets anywhere near hot enough to burn us.
    The glovebox on ours is styrofoam insulated, but would wager just ambient heat from the sun would melt a chapstick.
    Hope you get the results you desire. For the wife and I, the intense heat from the asphalt radiates far more heat than our Spyders bodypanels, or heat from underneath.
    But again, follow your plan and share with others if it works for you.
  8. #58
    Quote Originally Posted by exbrc1 View Post
    hi could you send me the pdf also? Thank you, Chip
    Chip, read post #34!
  9. #59
    Jan 2024
    Texas
    Post 34 doesn't have the mythical template that everyone is after, but does show how to mark your own cut lines. I'm hoping my kit comes with one, or might just put it on over the existing vent to see if that provides enough fresh air.
  10. #60
    SoFlo
    Shame none of the smart guys here did not 3D print scoops that could snap on to existing oem honeycomb style grille, instead of cutting up the bodywork.
    Another non invasive option would be to utilize the 3 position adjustable vents, and add a short deflector so that in full open position, those adjustable deflectors would force airflow down thru the honeycomb grilles. Far cheaper to modify the adjustable deflectors vs cutting the big hole in the bodypanel.
  11. #61
    Jan 2024
    Texas
    YES to both of these!
  12. #62
    Others have done just that, and AFAIK, none of those have gone on to cut panels - at least, none that I'm aware of have reported doing so here...
  13. #63
    Jan 2024
    Texas
    Ok, it was only 89 today so I took the bike out at about 5:00 with the sun still beating down and came back at twilight and and have proven to myself two things: The direct sunlight makes a huge difference and is responsible for most of the “too hot” experiences in the dash and glovebox area.
    However, even out of the sunlight on the ride home, there is very hot air coming up through the gaps between the panel and the handlebar/switches area. And the bottom speaker grills or vents have very hot air pouring up through them, even at 75mph. The glovebox is also still quite warm even after dark, especially at the bottom. I will inspect its insulation as much as I can when I get the plastic off next.
    So if I only rode < 90 F, I think no mods would be needed. But since that excludes 3-4 months here, I’m going to try the vents and extra insulation.
    (I was going to take actual surface temp readings but my infrared thermometer has broken. Replacement on the way.)
  14. #64
    SoFlo
    Your informal test validates how the acoustic panels not only serves to offer up a quieter experience from the engine, but also serves as a form to double insulate the exterior bodypanels from engine heat, and airflow leakage from the bodypanel seams.
    Myself, I never understood BRPs logic of complete removal of the acoustic panels. The heat barrier of those acoustic panels and secondary foam insulation bonded to the acoustic panel even further insulates heat from the exterior bodypanels and rider / passenger.
    Yes, installing the scoops will improve the airflow behind the bodypanels, provided there is forward motion, at adequate speed to sustain that airflow. When that airflow into the scoop is diminished, the heat and airflow behind the bodypanels becomes stagnant, ultimately heating those bodypanels the rider touches.
    While obvious heat rises. This heat rising, while semi trapped behind the bodypanels, will search for any exit as it heats all surfaces. The heated air can only be forced downward, if the scoops are functioning via airflow from forward motion.
    If you want a cooler experience, properly insulating the backside of all the applicable bodypanels is how to achieve less heat passed to the rider. Unfortunately, the heat barrier products, best suited for the task are expensive.
    In a previous reply, you mentioned reading about someone having replaced the oem inexpensive foam that had deteriorated. I suspect that was me, as much of the bodypanels and acoustic panels on our Spyder are lined with an exotic and expensive self adhesive insulation we use to insulate aircraft fuselages from the extreme heat and cold at altitude.
    So between the double barrier of the oem acoustic panel, and bodypanels, along with exotic insulation, radiant heat from the Spyder is a non issue, the true challenge now is the SoFlo sun trying to cook a person like a Thanksgiving turkey.
    FWIW, when we ride, regardless of ambient temps, the gear worn is a full coverage Shoei helmet, long pants, BRP mesh jacket over a shirt, full fingered gloves, socks, and shoes. That alone can get hot, I can only imagine how much worse it would be if the bodypanels added more heat.
    Will offer up something I sometimes do. If we stop for a short time, and the Spyder is shut down, there are times when the rising heat will get the Corbin seat a bit warm. Once remounted and moving, our fuel filler access door in the seat, which faces forward, I will open that, as if a ram air scoop, and within a minute, the actual seat temp is restored to a comfy level. This does not happen often, but is a huge benefit when needed.
  15. #65
    Jan 2024
    Texas
    Done!! I did a hybrid sort of install. I removed my existing grills but made no cuts.
    Shout out to the instructions sent, I forget by whom. The dental pick to mark the one angle screw hole was huge.
    My steps in summary:
    1. Used goo-gone to get the sticky off the new shiny front trim that comes in sticky plastic. Then used Dawn to wash the goo gone off.
    2. I followed the recall steps, skipping anything about cutting.
    3. I used the bolt and nut as to hold it in place then my hand to snug the rest while I marked then drilled all my holes, using a thin awl and dental pick. I used a 1/16 as a pilot hole, then the 13/64 as per instructions. (This was the first “no going back” mod I’ve done… was a little nervous!
    4. Then, again deviating from the recall instructions, I completely assembled the unit before attaching it to the bike. Otherwise not cutting the bike panel prevents putting some of the assembly screws in to put the unit together.
    5. Then screwed the unit onto the panel.
    6. Reassemble bike, bitch about how hard the left hand side bottom curved posts are to get back in.
    7. Wax the new parts to get them shiny and protected.
    Pics:
    one side on, one side OEM, for those that want to compare the difference
    Both sides on
    Side view
    Rear view
    More leftover oem parts for my collection.
  16. #66
    Wa.
    Allen, you did a good job of adding the vents to your Spyder. They look nice, good job you did.
  17. #67
    Jan 2024
    Texas
    I am happy to report adding the intake vents is mission accomplished! I started a ride today at about 5:30 today at 90 degrees. Zero warm air coming up through speaker vents or openings between panels. In fact I think there is some suction perhaps. Glove box not even a little warm! As a final test I need to getting overhead sun at 95+ again, but I am very pleased with this mod.
  18. #68
    Sep 2024
    MO
    Does anyone know if I can just buy the air scoops and support bracket? BRP and the dealers can't tell me what comes in the kit.
  19. #69
    Jan 2024
    Texas
    Read my posts above. Yes, I found the scoop kit in stock at a dealer. Part #219800388
    Depending on your year, you may not have the acoustic panel to replace with the bracket. My 2019 did not.
  20. #70
    Sep 2024
    MO
    Do you have the instructions and template you could email me?
  21. #71
    indpls in
    can you make your own template now that you have the vents cardboard works
  22. #72
    May 2018
    Chateauguay, Qc, Canada
    Quote Originally Posted by Harleyman1000 View Post
    Yes I do. PM me with your email and I send you the details.
    Eckhard
    Spyder RT Ltd, 2011
    2011 RT Ltd. , Pearl White
