Results 1 to 9 of 9
    Active Member GreenDragon's Avatar
    Oct 2014
    Dillsboro, IN
    Default Signature & photo
    I have tried to download/upload/insert a signature and signature photo. I can not get it to show up on the posts. Any help would be apprecaited.
    Thanks in advance!!
    Default Let's see..!!
    Go to settings...go to edit signature...I'm sure you have done this already. Now put the signature information in and if you are adding a photo go to the picture box on second tool bar and select picture from file. Should take you to the pictures on your device. Select the picture and then click on upload. May have done all of that too..now you should have what you want to appear...save signature and it should work for you...at any rate thats how I did it...good luck..
    Gene and Ilana De Laney
    Mt. Helix, California
    ​2012 RS sm5
    Oct 2014
    Dillsboro, IN
    Thanks, but that is what I have done and it still does show up.
    May 2013
    Edmonton Alberta, Canada
    Are you sure you are putting it in the right window?
    When you are on the edit signature page, the first window is the preview window.
    Scroll down to the next window and place it there.
    Oct 2014
    Dillsboro, IN
    I have done all the above and all that shows up in the upper window is a notatation saying "sigpic" but no photo, even though I have "inserted" the photo from the lowere box. I have tried to resize it thinking that may be the issue but that has not helped either.
    Oct 2014
    Dillsboro, IN
    Don't know what changed but now it is there. Thanks every one.
    Active Member cruisinTX's Avatar
    Mar 2015
    Fritch, Tx
    I have the same dilemma. After trying all of the above advice, nothing has changed. Maybe posting this new reply will make it happen. not holding my breath though.
    Those who say " I can't" will always be right.
    Mar 2015
    Fritch, Tx
    Quote Originally Posted by cruisinTX View Post
    Well I'll be darned; that did it.
    Server Admin AnthonyG's Avatar
    mi
    The signature change requires a post after chaning/adding to it, as its cached for performance.
