Results 1 to 7 of 7
    Active Member Badco149's Avatar
    MERRIMACK
    Default Replace original handlebars with Attitude bars. 2016 F3 Special
    I would like to replace the handlebars on my new 2016 F3 Special Limited. It looks like it is pretty basic but with the heated grips and other accessories I a not sure of the complexity. Is there a video or document that shows how to do this. I am somewhat mechanical. Or is this something you recommend I go to dealer and have them do?
    Badco
    2016 Spyder F3 Limited Special Series
    Mar 2013
    Maumelle, AR
    Quote Originally Posted by Badco149 View Post
    Badco
    It's a very easy job. The dealer allows less than 30 minutes to change them.
    2020 RT Limited , Chalk
    NorCal - Northbay
    You actually won't even be messing with the grips/controls. They separate from the bars as complete units when you remove the upper and lower caps. Just put a blanket over the bodywork to protect the paint cuz you need to lay them out of the way while you R&R the bars. There are guide pins on both the bars and the control/grip assemblies to orient everything. You will get all new hardware, with pre-applied locktite etc if it is an actual BRP accessory....
    I have not used the attitude bars per se but I did do this job switching to the drag bars.
    indpls in
    Default windshield
    what windshield is that on your limited i want a different on for my limited special
    Jul 2015
    Easley, SC
    Here is a link to the instructions for installing the handlebars.
    http://instructions.brp.com/content/...0548,219400550
    2015 RS SM5, Navy F4 Fighter wrap
    Passenger Backrest, RT Handlebars,
    BRP Comfort Seat, Airhawk R cushion,
    Garmin 660LM GPS, LidLox, Can-AM Top case
    MERRIMACK
    Quote Originally Posted by fatboy View Post
    Hi The windshield is the BRP Tall Boy. I just installed it a couple weeks ago. I like it much better then the low boy that came stock.
    Here is the link.
    http://store.spyder.brp.com/product/...Boy_Windshield
    Badco
    MERRIMACK
    Quote Originally Posted by hypurone View Post
    Thank you very reassuring. I have replaced the windshield and added the back seat rest and that went well. So I will give this a try.
    Badco
