What is the plug under the seat? Pictures added
I've got all the parts and pieces ordered to mount my GPS in the center of my handlebars. I looked under the seat and see a rubber capped plug. What is that for? It looks like a good power source and it is fused.
2012 RT-S SE5
No Mods (yet)
if it is the plug going into the passenger seat it is the ABS sensor to tell the system when there is a passenger,DO NOT mess with it.
2015 RT White,Tj's Dash mount,Rivco's Duel Flag Holder,SealsFloorBoards(Pups),Custom Dynamics fender lights(R/W)Bajaron's Swaybar & links,Lamonster's LED headlights,lidlox.Wiredux A-arm driving lights(upper&lower)FOBO TPMS system,Spyerpops lighted bumpskid,Foom handgrips. tobor9@me.com
He described itas "Rubber capped"... that doesn't sound like it would be for the weight sensor in the seat...
I am guessing it's a RT because you posted in the RT section. Other than that we know nothing. But I will make a wild guess it is a power plug for optional equipment that a former owner had. A picture is worth a 1,000 words.
2018 F3 LIMITED
Nothing comes OEM under the seat with a cap on it...
If this is a used Spyder, I might guess a hook up for a battery tender. Ihave one that sounds simlar.
If it is used, he/she might ask the dealer to contact the seller and ask what it is. If it is not factory, who knows. Might have to trace it.
Oldmanzues
Actually there is a positive terminal under the RT seat with a rubber cap on it. I lost my rubber cap during my ride to SF2013. I would not mess with any of the terminals under the seat though. If you got the BRP mount it should have the wires to run the GPS the right way. Pull the panels on the right side and plug it in where it is supposed to be would be my recommendation.
I'll get a picture, but this is a brand new 2012 RT-S SE5. I've had it 4 weeks (2 weeks of which has been raining) and turned 1000 miles yesterday. I can't find it mentioned in the manual anywhere. It's not the battery terminal. I would call it a "pigtail" with a rubber cap on the end that when removed, exposes 2 male plug terminals. I may put a volt meter on it and see what I get.
I'll get a picture in day or 2,
Thanks,
Jeff
2012 RT-S SE5
No Mods (yet)
RT-S PE#0027
Sounds like the dealer may have installed a battery tender plug. There are quite a few dealers up this way that do that at time of prep.
Sent from my SCH-I605 using Tapatalk 2
Back amongst the living May 2021
2022 RT Limited Hyper Silver
Out to Pasture:
2013 ST Limited , Black Currant
2022 F3L , Dark Edition
2021 RTL , Chalk Chrome
2013 RT Limited , Circuit Yellow Metallic
2008 GS SM5 , Millenium Yellow
2020 RT Limited Petrol Dark
2014 RT Limited Champagne Black
2012 RT Limited White
2010 Timeless Black RTS SM5
2010 Orbital Blue RTS SM5
2008 GS SM5 PE 1941
2008 GS SM5 PE2011
All the tender pigtails I have ever seen have one male and one female -- not two males. (Shock prevention purposes.)
Post a pic when you have time...
Also, do you have the communication package with your Spyder? I am wondering if it isn't an audio cable of sorts to be used when the comm package is installed; whereby it then gets routed under the housing where it would not be seen.
Do not know this for certain, but I have my suspicions...
SL #7026
VBA #652
HOG #3935417
2011 Viper-Red Spyder RT SE5 & Trailer
2017 HD Ultra Limited
Former Rides: 2014 HD Ultra Limited; '04 Kawa Nomad; '09 HD Ultra-Classic; and many Hondas through the years.
Spyder Newbies Do's & Do Not's: http://www.spyderlovers.com/forums/s...-Spyder-owners
When I bought my spyder the dealer installed a plug to plug in a battery tender, sounds like what you may have.
plug
I have the same bike a 2012 se5 RT and their is a Red capped positive terminal under the seat on the left side if sitting on the bike and on the right side their is a ground bolt I connected my heated vest and air horn to it and its been fine so that's what it is but be careful not to short a arch if your gonna use the red terminal and loosen it up with a metal wrench or socket it comes off just go slow and good luck hope this helps Rich oooops that's different then the one I have ??
SpyderLovers Sponsor
IS THIS WHAT YOU HAVE ???
If this is what you have it's a fused ( mine is ) cord leading to your batteries
Positive and Negative used for a battery tender/charger
I agree with this one. Two male terminals, no idea
Oldmanzues
My 2012 RTL has a battery tender hookup under the seat. I wasn't sure what it was for but when I had the panels off to check the battery connections I followed the wires and they hook up to the battery.
2016 F3 Limited
2019 Ryker Rally
2014 Suzuki V Strom 650
2020 CSC TT 250
Teddys favorite human
I added a couple of pictures.
Thanks for the welcome CyncySpyder!!
2012 RT-S SE5
No Mods (yet)
As mentioned by others your photographs look exactly like the pigtail I installed for my battery tender. If so, not a good source for power. Mine is fused at .5 amps so won't carry much of a load.
2012 RT Limited
SpiderWrap Graphics
KewlMetal DualKewl FenderZ Running Lights
TricLED Dual Running & Brake Lights
Seal Floorboards
Bajaron Anti-Sway Bar
Utopia Backrest
Diamond R Luggage Rack
SpyderPops Upper Blockoff
SpyderPops Catalytic Converter Shield
plug looks polarized. could only be connected one way.
Motorbike Professor
Appears to be a propietary battery charger pigtail for the NOCO Genius smart charger. These are sold by Menards, among other places. I have a couple of them, and I like them, but I do not like their proprietary pigtail. Most chargers use an SAE connector, so these end up needing an adapter to attach to an SAE equipped vehicle. BTW, standard fusing is 10 amps for the Genius charger pigtail.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
Scotty is right, again! It's a connector for the Genius Battery Charger. Look at the accessories page particularly the item identified as the "GC016 12V Dashmount Battery Indicator" near the bottom of the page.
Baja Ron - Dimple - Ultimate - Lamonster Garage - K&N - Smoothspyder - Amsoil - Hiflo - FOBO - Spyderpops
Sena - Dynaplug - Shoei - Tourmaster - Garmin
Ding Ding Ding, I think we have a winner!
Thanks to everyone for their input.
Jeff
2012 RT-S SE5
No Mods (yet)
