How can I open the Glove Box on RT Limited? Pressing down wont work!
I cannot open the glove box on our 2012 RT. Any suggestions are appreciated....
Gary
Teddys favorite human
Turn the bike on and make sure the steering isn't locked, cause it also locks the glovebox.
I use a light smack with the side of my fist and it opens every time, pushing down does not work well on mine either.
I'll be interested how this issue end up
2012 Spyder RT SE5 Brake pedal mod
GOS member (Girls On Spyders)
I have found if I push to hard it will not come open and if I slam it closed it will not latch.. so you might try a lighter touch..
Motorbike Professor
If anything pushes back, it may not unlatch. It sounds like your latch or cable needs adjusting or repair/replacement. I'd see your dealer before you are accused of damaging it.
-Scotty
2011 Spyder RTS-SM5 (mine)
Mutant Trikes Forever!
I have the same problem with mine, it does not want either to open or close, so I finally have just stopped using it.
Can't Open Glove Box
Originally Posted by akspyderman
Light pressure or make sure the steering is not locked. Remember to push in on the key when turning. If these don't work, have the dealer take a look. A broken into or broken glove box mechanism will end up costing you big bucks. I am guessing not a warranty item if broken by the owner.
Let us know what happens.
Thanks for all of the suggestions..... nothing seems to work, so I'll take it to a dealer.
Motorbike Professor
The key has nothing to do with the glove box...unless the steering is locked.
-Scotty
