Results 1 to 19 of 19
    Default More Turnsignal Indicator Lighting
    Hi Guys!
    I figured it best to get an early start on the WinterTime projects on my RT... (Well... That; and The Missus is madder than a wet hen at me! )
    So off I go to the garage to hid...errrr work on the bike!
    Removing the mirrors... It's a tricky thing to do when you don't do it every day to keep it fresh! After wrestling with each of them for about five minutes, they gave up and popped off into my hands. Unplug them, and we're off to the races!
    I decided to mount a 3 LED strip on the inner wall of the mirror housing; it wouldn't blind me with a lot of glare, it would be visible to traffic behind me and in the next lane, and hopefully it'd be easier to find the wires once I pushed them down into the housing. (I left them together for this job!)
    Layed on some primer that I had gotten from Reggy; once it was dry I stuck the LEDs into place and got to the point of no return: drilling holes!
    Held my breath and said a prayer and punched some holes into the housings. Then I fished all of the wiring down through it and into the bowels of the darn thing; without a clue as to how I'd find it and pull it out!
    I fashioned a hook on a piece of wire and went fishing... I found one and pulled it through so fast that it worried me... Sure enough; the second one was a real pain in the as... rear!
    After forty minutes or so of looking dumber than normal, I managed to snag it and was back in business. Being careful to hook ground to ground and positive to positive on BOTH sides, I did a quick test with a battery... Back to the bike; I wrestled the mirrors back into place, and here's the results: More Turnsignal Indicators 001.jpgMore Turnsignal Indicators 002.jpgMore Turnsignal Indicators 004.jpgMore Turnsignal Indicators 005.jpg
    Very Active Member mrfats's Avatar
    Jul 2011
    Morgantown, WV
    Bob, good idea! And I like your Mini...
    Registered Users quickster47's Avatar
    Jun 2012
    Cumberland Cove - Monterey, TN
    Nice job Bob.
    Carl
    2012 White RT Limited and 2013 Yellow ST-S Think 3 .i.
    Mar 2008
    Allegan, MI
    Nice job, Bob. I hope you can make it to a Spyder event somewhere outside your backyard someday. I'll give you a lesson or two in removing the mirrors. A five minute struggle is a bit much!
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Invalid Emails
    Aug 2010
    Guelph,Ontario,Canada
    A Job well done , Bob
    Very Active Member IGETAROUND's Avatar
    Oct 2011
    Kalamazoo, Mi
    nice job Bob!! pretty intricate work for the hopelessly wrench challenged
    All the great movements in the world began with a cup of coffee!
    2018 F3-T
    My mods: Can am Trailer hitch, USB and 12 volt power outlets, Gustason windshield, Bead rider seat cushion, battery harness for electric gear and battery tender, Time out trailer.
    2018 F3-T , Pearl White
    Sep 2012
    fort lawn south carolina
    Default great job
    great job on the installation I got six leds I bought 2 months ago and cant find someone really close to help install them found a nice man Mr Brinker will help but he is over a hour or more away and when ya dont trust ya bike and its cold outside cant get up to him BUT your a better man then me to drill a hole also I,am not brave or smart enough to get mine on yet ride safe Rich
    Hi Rich,
    Believe me; the drilling part had an "Off The Chart" pucker factor...
    Since I mounted it on the inside edge, I just drilled the hole right below the LED; kind of on the bottom...
    I pushed all of the wiring into the mirror body, and caught it through kind of a slot down at the bottom. Above that slot was a smallish hole; I wound it through that and then back out the bigger opening that the OEM wiring uses. (I did that to kind of lock it in place and have it routed alongside the OEM)
    Scotty; YOu're absolutely right! When they popped off; they just popped off as simple as anything. (I STILL don't know how they did that!)
    Teddys favorite human CyncySpyder's Avatar
    Jun 2010
    Covington Kentucky/Cincinnati Ohio
    Thumbs up Teddy says Congrats Bob on a mod well done
    Jun 2010
    Las Vegas
    Good job Bob! Did you get the sway bar on yet?
    2014 RTL-SE6 8,600 miles
    2011 RTS-SM5 5,000 miles
    2010 RTS-SM5 59,148 miles
    2010 RT- 622
    washington state
    During night driving, are these added lights don't blind you?
    2012 Spyder RT SE5 Brake pedal mod
    May 2009
    Connecticut
    The Dual Color White/Amber and Red Front Fender LED,s would do more (IMHO) to define your perimeter and are very easy to connect!
    Tric LED or Custom Dynamics sell them.
    Sea Doo GTI-SE 90 Jet Ski!!
    Jun 2012
    Hampton, Virginia
    Default Damn Mirrors!
    Quote Originally Posted by NancysToy View Post
    Scotty I'd like to take you up on that mirror removal lesson or two...see ya at Spyderfest!
    2016 F3-L Special Series? Mods: Lamonster IPS end caps w/ Gripper 3rd pegs, GPS mount, Power Plate, Perf. Muffler; Backoff Brake Light Strobe; CD Front (amber/red) Brightsides & Tip Kit; ISCI Flag Holder w/Long Poles; BRP Signature Light, Aux Lights, Saddlebag Liners, Garmin 590 GPS; TricLED foam Grips, LEDs (Aux/headlights); Pitbull Driving Lights; RDL seat; Ultimate backrest
    Previous ryde: 2012 RT-L, 26,636 miles on it when traded; 2014 RT-L, 34,147 miles on it when traded
    Quote Originally Posted by jerpinoy View Post
    Since they're not directly pointed at me, and they're not on the mirror's surface; they don't seem to cause that problem.
    (This issue was one of my major concerns with some of the other mounting locations)
    Invalid Emails
    Aug 2012
    Lawrenceville Georgia
    I love the way they look. Just might have to steal your idea.
    Very Active Member DocRags's Avatar
    Jun 2011
    Milton, FL
    Quote Originally Posted by mrfats View Post
    I like your Mini, too...but it needs Carlashes!
    2008 GS Phantom, 2012 RT Limited
    Cheryl Reinhart Ragsdale
    I showed the Carlashes to The Missus; she didn't bite... But she did snarl just a little!
    Tomite,
    It ain't stealin'... it's in here so that it's free for the taking!
    Registered Users Spyderific's Avatar
    Jun 2012
    Alberta
    Reggie at Tricled makes a kit for mirror mounted signal lights. They mount above the mirror along the top edge of the mirror housing, horizontally. I just got a set from him and they look and work great. Pictures of them on Tricled.
    2012 RT Limited (White)
    Tricled fenderz, 3rd and 4th brake lights, mirror mounted rear signals and tip lights. HID head and fog lights. Smooth Spyder. Bajaron Swaybar
