Results 1 to 13 of 13
    Registered Users Clicker1944's Avatar
    Apr 2010
    Cocoa, Florida
    Default Push button frunk opener
    Well mine stopped working yesterday. Key still works but electric switch is a no go. Has anyone had the problem and what was the fix?
    2011 RTS SE5 Chrome Dash Kit, Best Flame Kit, Chrome handle bar end caps, Chrome Tail pipe tip and heat shield, Chrome Handlebar Cover.
    Perhaps that little switch up front got bent??
    Right hand side under the black cover... There's a cutout that allows for a small arm from that swtich to do it's magic.
    It's easier than to bend that arm if you're playing under that cover...
    Teddys favorite human CyncySpyder's Avatar
    Jun 2010
    Covington Kentucky/Cincinnati Ohio
    Angry Yeah, what Bob said
    They bend & break easily as we've had to have two replaced now If in the off chance your switch ISN'T broken, I'd suggest checking the fuse for it
    Arkansas
    A couple of months ago, we had started up and were ready to pull out when hubby wanted something from the frunk. I pushed the button but it didn't work. Had to turn the bike off and use the key to get him in. The next day I wanted in and pushed the button. It worked. Only thing different was that I was in neutral instead of first gear like the day before. Maybe this is it?
    Very Active Member eddieshep999's Avatar
    Oct 2010
    Broadstone,Poole, Dorset, UK
    Just on the off chance suggest you try the Switch with the engine running
    On my Spyder RT-S SE5 2010 Model the front trunk switch only works whilst the engine is running
    I understand later models were updated to allow the switch to work whilst the ignition is on but the engine does not need to be
    running
    Sorry not sure ref the later models but someone will be able to put me right or at least give you up to date information on your model
    of Spyder
    The note ref the switch under the Funk - Looks like a metal strip Very valid they can break - Mine was done accidently by a dealer who replaced it free of charge
    Eddie Sheppard
    Reading UK
    Mar 2008
    Allegan, MI
    One other common cause is a need for latch lubrication...and possibly adjustment. One task that is neglected by owners doing their own maintenance, and even many dealers, is periodic lubrication of the latches and hinges.
    -Scotty
    2011 Spyder RTS-SM5 (mine)
    Mutant Trikes Forever!
    Jun 2010
    Post 23B in the schematic is the Position Sensor we're all talking about
    Apr 2010
    Cocoa, Florida
    Thanks all...here's an update if I push on the frunk and push the button it works. So it looks like the switch may be misaligned.
    On the 2011 it does work without the engine running.
    Yes I was in neutral.
    Thank you all again. I will either try to adjust it myself or stop at a dealership when in the area of one.
    Very Active Member stevedfive's Avatar
    Aug 2010
    Riverside, California
    Mine did the same thing. I put a piece of 3/16" rubber underneath the switch (double face tape) and it fixed the problem.
    2014 Timeless Black RTS/SE - BRP CB/Comm System; BRP Zumo 660 GPS System; BRP Cellphone Interface; BRP ST-1 Helmets w/BRP Headsets; BRP XM Radio; BRP Tri-Axis Handlebars; BRP Adj Wind Deflectors; BRP Adj Vent Windshield; BRP Comfort Seat & Utopia Backrest; Corbin Armrests; HMT Brake Light; TricLED 3/4 Brake & Running Lights; TricLED Fender Lights & Rr Cargo Lights; CD Fender TIPS Kit; Bump Skid; Scorpio i900 Alarm; Touratech GPS Locking Mount; NBV Highway Mounts; BBP Brake Pedal, Stebel horn.
    Mar 2008
    Allegan, MI
    Quote Originally Posted by Clicker1944 View Post
    I suspect you have a trunk liner and the trunk weatherstrip has been pulled off on one side and is intruding into the opening...pushing up on the lid. You could also need a latch adjustment. Lubricating the latch and latch post should help...but check that weatherstrip.
    -Scotty
    Apr 2010
    Cocoa, Florida
    Quote Originally Posted by NancysToy View Post
    Bingo...the weatherstrip was the culprit was barely noticeable. Thanks!!!
    Jun 2010
    Thumbs up Can you imagine our lives without the support of this site- THANK YOU ALL
    Just one more reason Teddy & I LOVE SpyderLovers
    Teddy says that deserves a 'HIGH 5'
    Scotty is everybody's "long distance mechanic"!
