Baker CanAm Spyder RT Instant Air System
Has anybody installed the baker Rt air system? Any feed back from those that have it would be great.
Proud Owner of a 2017 f3t
I had Baker airwings on my Goldwing.They were amazing.Should work equally as well on thr RT.
They work great, cool air/warm air when you need it.
Have them on my RS,they are Great!
2015 RT White,Tj's Dash mount,Rivco's Duel Flag Holder,SealsFloorBoards(Pups),Custom Dynamics fender lights(R/W)Bajaron's Swaybar & links,Lamonster's LED headlights,lidlox.Wiredux A-arm driving lights(upper&lower)FOBO TPMS system,Spyerpops lighted bumpskid,Foom handgrips. tobor9@me.com
I put them on my RT. They work! The Spyder was a warmer ride than I was used to and in all but the hottest weather the wings make a difference. They also kept me much warmer this weekend when we rode in cool weather AND they keep me drier in rain. I recommend them.
summerdawn
Guys this is what i am talking about. Not the air wings. I have the air wings and they do work great.
Can-Am Spyder RT Instant Air System
• Raise or Lower Rear Air Spring Pressure While Sitting on the Seat
• A Must for Night Ridinig as Air Pressure Directly Affects the Head Lights on Oncoming Traffic
• Instant Air System can also be Used to Inflate Tires
Can you grab us a link to their site? Thanks!
May all your encounters with the law begin with the words: "nice trike!".[/B]
2015 Can-Am Spyder F3-S SM-6 Can-am Red/Black SM-6 with 2010 Black RT-622 trailer (hitch in the works).
Previously owned:
2010 Can-Am Spyder RT SM-5
2011 Can-Am Spyder RS-S SM-5
2013 Can-Am Spyder RT-S SM-5
Teddys favorite human
Interesting- Is this a similar system that is already installed on the RT-S & Limited
Under Seat View of Wiring and Plumbing
Attaches to Existing Air Spring Valve
Air Compressor Mounted in Right Side of Rear Trunk
Takes Up Less Than 5% of Trunk Space
Gauge & Switches Mounted in Lower 1/3 of Glove Box
Can-Am Spyder RT |
Instant Air System $299.95 USD |
Looks like it does the same thing. I have a hard time buying that it can make that big a difference in the aim of your lights, but I have never really tested to see what the delta is between all the way down and all the way up.
Can-Am Spyder RT |
Current Bikes:
2018 BMW K1600 B
2012 Spyder RT LTD - Sold
2003 HD VRSCA (VROD)
The fact that it can also inflate tires is intriguing.
I wonder if you screwed an air hose to the valve under the seat and pushed the magic button; would that work as a source of air for ACS ryders?
Baker CanAm Spyder RT Air System
Yep, I've got it on my 2011 RT A/C. Works great. Bruce was offering it at Spyderfest but I ran out of time so had him install it at his place later.
Did I say, Works Great.
I have both the Air Wings and the air ride. Works great. I must have a pin hole leak somewhere in the factory stuff. Pressure would leak down over 3 or 4 days.
He put the system in somewhere, do not remember where, but a long time ago.
The pressure is controlled with a button he puts in the glove box. The main unit is in the trunk. That is a mini air compressor, hooked up all the time. I have unhooked the compressor from it retaining straps and used it several times. Inflacting the Spyder tires and a couple other bike tires, not mine. The cord from the outlet in the trunk to the compresser is about 15 ft or so long.
Good luck, hope this information helps.
Oldmanzues
It would be tricky.
I too had the same idea as you, but in order for the ACS to work when the bike is stopped, you have to be in gear with your foot on the brake.
I guess with two people, you could make it happen, but I just gave up on that idea and ordered a small compact air-pump to keep in the trunk instead.
magical member
Originally Posted by revjvegas
It would be tricky.
As long as the engine is running the rear air adjusts on my 2012, I don't have to be in gear or foot on the brake.
harry
"Draco dormiens nunquam titillandus"
My Rides;
Nimbus 2000, Ford Anglia, 2012 Spyder RT Limited, Pre 14 Vintage Classic Collectors Edition!
Favorite Ride;
Nimbus 2000 boy this thing can fly.
Mods:
Charm of invisibility, Reparo Charm (cuts down on service cost)
One always wonders about roads not taken.
My 2010 does need to be in gear for the ACS to make magic happen.
It sounds like a great way to run over yourself while airing up the tires!
What is ACS ????
This appears to be less expensive than the BRP kit.. Which I don't think even has a gauge... ugggg.
Looks kind of like a Slime compressor.......
Spyder #1 - 2008 GS SM5 Premier Edition #1977. RIP after 80,000 miles.
Spyder #2 - 2012 RT SM5. Traded in after 24,000 miles.
Spyder #3 - 2015 F3 SM6. Put 13,000 miles on and sold it.
Spyder #4 - 2017 F3 SM6. Too good of a deal to pass up!
Harry...that's curious. Wonder if that's just a feature of the 'Limited' ?
Because I must say, it would be a very cool feature to be able to use that on-board compressor to be able to air up when needed.
I know mine, I have to follow the procedure outlined in the MOM to get it to work.
Adjusting Suspension (when Vehicle is Stopped) Follow the same instructions as for ADJUSTING SUSPENSION (WHILE RIDING). However the following conditions must be met: – Engine running – Brakes applied – Parking brake released – Gearbox not in neutral.
And thing is, you know they could make that work with just a little change to the firmware. Oh well.
Oh, and I think ACS = Air Controlled Suspension
Dick574,
Thats just what I wanted to hear. I will get it ordered fron Bruce today. Getting tired of having to put air in the shock every week.
Thinks out loud
If your lights are adjusted when the rear shock is at near minimum inflation, increasing inflation on the fly will cause the headlight beam to lower noticeably.
Yes we like our Baker wings
Fly,
I've got to admit that what the letters stnad for has escaped me for the moment... It is of course, BRP's onboard suspension adjusting system. You can add it to your A&C if you wish...
The kits are all over EBay; I picked one up for $418 and some change
They say that it's about 3.5 hours to install it; I let the dealer do it and it cost $325... money well-spent!
Okay.... seems to me the Baker setup is better... as it actually has a gauge.... and can double to fill your tires up.
I may try to make my own setup like this... already own a slime compressor.......
Has anyone installed it themselves???How much of a PIA is it to do???
