Yokohama S. Drive rear 205-55-15 tire; Federal 165-55-15 Front tires F3/RT Spyders
why dont you guys try RE003 165/55-15 ?
They work much better than the TW tire:yes:
Can you clarify your post...what is "RE003"? What is "TW tire"? Not sure if anyone else said, huh? But I didn't understand any of this.
Federals
Update 21 Oct 2016:
The new design front Federal Formoza AZ01 165-55-15" tires have a smoother ride, very good grip in corners rain or dry roads; 17# air, I used 10oz "Ride On" sealant/balancer each front tire.
I have over 3,000 miles on new front Federal AZ01 tires 2015 F3S SE6 "Touring mod" Spyder, very good grip/handling, smooth ride.
http://www.newegg.com/Product/Product.aspx?Item=9SIAB0Y48R8175
Rear Yokohama SDrive 205-55-15" tire at 23# air has excellent grip/handling rain or dry roads, smooth ride, good wear (on my 2015 F3S, 15,500 miles).
A good combo front & rear for my 2015 F3S Spyder, or other Spyders.
Another car tire option for your Spyders.
Enjoy your rydes.
Jim
Thanks for the pics and info. Do you like the AZO1 better than the EVO. I am on the fence as to which one I am going to get. I found a pair of AZO1's cheaper than the EVO's. I just dropped my YOKO [with 8,000 mi. on it] down to 20 lb. and have only ridden it 50 mi. since but the only difference I notice so far is a smoother ride so that's where it will stay for now.
CHOICES
..#1, The EVO is loved by the folks that are into " DRIFTING " with cars !!!! .... I think because they SLIDE better !!!!!!.............#2. At 20 psi in the WET you will like your tire even better because it will have more TRACTION .... the SIPES work better ............... good luck...... Mike :thumbup:
Your welcome with ryding info I shared on experience with Federal Formoza AZ01 front tires with 3,000 miles on them.
I like the new designed Federal Formoza AZ01 for noticeable better grip in corners & not as firm ride as the EVO was for 18,000 miles.
The Federal Formoza AZ01 front tires have noticeable better grip in tight switchback corners; (tested on 1200 switchback sharp corners in 90 miles on Coronado Trail ("Devil's Hwy 191" NE Arizona mountain road, last Monday 17 Oct 2016)!!
AZ01's are a good match for the rear excellent grip high performance summer Yokohama S.Drive 205-55-15 tire, on my 2015 F3S Spyder.
Jim
p.s. Here is a update photo of Yoshimura RS R77 muffler I put on my 2015 F3S Spyder, Pitbull's Sidewinder exhaust pipe, (with Lamont's exhaust deflector).
Gives 1330cc triple motor a nice mellow sound!
Yoshimura RS muffler on 2015 F3S Spyder Sept 2016 IMG_4130.jpgIMG_4119 Federal Formoza AZO1 165-55-15 front F3 tires.jpgExhaust pipe back pressure restrictor 2015 F3S Spyder IMG_4128.jpg
