Yes nanny is very sensitive
r1100rider
Solved my Hid install causing VSS code, I had the hid feed wires plugged in to the stock lite socket and then put them back under the rubber boot inside bulb housing, apparently there is enough electrical hash off of the ballast wire to the bulb to freek out her Highness because move the connector outside the the lite housing and she is all happy now , YES NANNY HAS VERY SENSITIVE FEELERS
Good to know..!!
for all those installing HID. Maybe thats the problem with some of the others..thanks for the update..!! :2thumbs:
