Y-gaskets
Mowerman
I am feeling a lot of heat on the right side of the RT. It is right around knee level. The plastic gets so hot you can barley touch it after a long ride.
Would this be the Y-Gaskets going bad?
:dontknow:
How many miles on your Spyder? Most most gasket failure happen at 6 to 8 thousand miles. And usually the first sign is noise, than heat.
9000 miles and it is louder then it has been.
I would pull the right side panel [the right side usually fails first] And look for black exhaust stains around the gasket joint,
Also when the pipes are COLD start the engine and put your hand next to the gasket joint feeling for an exhaust leak, Careful the pipe gets hot quick.
If you find you need new gaskets go with the Honda Goldwing gaskets.
I spoke with the Techs at East Coast Cycle Center in Bensalem, PA about the gasket issue when I was in there on Saturday for the 600 mile check up on my new RT-S. They said they always use the Honda gaskets on the Spyders when they have to change them. (They always have them since they are also a Honda dealer)
So they're doing "gene splicing" experiments right in their shop... :thumbup: I wonder if BRP has figured out why they don't sell any Y-gaskets there?? :shocked:
