Desert Spyder
which xm radio can you buy for a RT and how do you mount the antenna? I would love to listen to it through my helmet Sena's
There's always BRP's optional XM receiver that plugs right into the existing entertainment system... :thumbup:
But for $50; I went the CHEEP route!
I bought an XM Onyx receiver, and mounted it in the top trunk. I use the 12 volt power source back their to give it some juice, and I use the MP-3 Player patch cord, to tie the output into the existing system. The antenna is that little plastic "egg"... it sits on the shelf just over the lip that seals the top trunk from the elements,
It ain't perfect: I've got to stop in order to change channels. But for the savings... :clap:
If I can get the camera and the bike in the same place... :thumbup:Would you guys mind uploading pictures for all of us?
We run the Zumo 665 to listen to XM on our RT.
Hi RUOUTHERE,
I have a 2013 ST Limited. Do you know if the Zumo 665 works on the same mount as the 660? Is all of the wiring compatible? Does it require another antenna for XM/
Thanks,
John
I made a box out of Kydex sheet. Mounted it in the trunk to hold my Roady XM radio. It's now plugged into the Spyder's plugs. One for power and one to the radio control. Made a slot for the antenna wire at the top left of trunk so that it wouldn't get pinched and broken. It's a cheap after market antenna. I set the station at the radio.
here's my setup
I run wires from the battery for power and then the audio is run under the seat to the trunk![]()
