SpyderAnn01
Did you take it up to 30si, in order to get more even wear across the tread pattern? :dontknow:
Yes, I ran the second Arachnid at 30, but I was too late as the outer edges had already lost tread.
I've got just short of 7000 miles on my Spyder now, and I too need to replace the the rear tire. Was gonna do it at SpyderQuest, but I don't think I'll make it till then. So I've been reading the various tire threads here on the forum. The Kumho Ecsta AST definitely seems to be the car tire replacement of popular choice, but Ann's comments are not the first I have read concerning "less than optimal" handling, especially as the tire begins to wear and especially in the rain. Not sure why, because that deep "V" cut would seem to throw off the water really well.
A lot of folks have recently shown interest in the Yokohama s.Drive tire in size 205/55R15. That tire is slightly narrower than the Kendra, which some have hypothesized would cut down some on the tendency to wear more in the center. However, it is exactly the same diameter as the OEM tire, so there shouldn't be any changes in how the Nanny or the speedometer react to it. Folks have said that it grabs the road a lot better than the Kumho, and it also wears well. But the jury may be still out because I don't know of anyone who has had it yet for several thousand miles. (Perhaps others will chime in here if they've had the Yokohama s.Drive for several thousand miles.) However, given what I've read about the Yokohama here on the forum, I think it will be the rear tire I will install on mine.
Do a forum search on "Yokohama" to read what others have said about it. (Same goes for "Kumho".)
I had 4,500 miles on my 205-55-15 rear tire on 2014 RT (before I traded it in).
The S.Drive is a much better grip tire, a smoother ride (not as harsh as Kumho on small bumps), seemed to not wear at all in the 4,500 miles.
(You can go double the posted speed in corners on RT with the S.Drive tire, it grips that good).
I would recommend the tire.
Firestone tire shops usually can spin balance rear; & also front Federal tires/wheels on Spyders.
Jim
Jim, do you have any experience in the rain with this combo?
if you Google the tire size you will see how limited the choices are. :banghead:Why do many of you put one brand of tire on the rear and another on the front?
I think that it may be a question of getting the proper size of tire.
The rear tire size(s) are pretty common.
The fronts: not so much... :shocked:
Have been following the tire thread.... But, am getting confused on all the different opinions!!!! I need to replace my back tire on my 2014 RT-S. I'm thinking of going with the Michelin Defender 215/60/15. Does any one have this tire on their Spyder? Do you like it? How was the wear?
Thanks for the information.
Teri
Love the wide groove and smooth roll on the front at 19.5 psi. We put them on about 20,000 miles ago and balanced by Discount Tire. Probably the last tires we will put on the front as they're a 60,000 plus rated tire. The wear has been great and maybe we'll look at the Defender for the next rear tire change although the Kumhos have been good so far. Haven't tried to keep up with any GS's or two wheelers, but this combination keeps up with the RT's and trikes we ride with.
Click on the Go Advanced button. Then you can.Please ignore the typo in the title... Can't edit it out..
Teri
