3Ryder
I am returning home from visiting Works Performance in Canoga Park, CA. It was worth the ride and we accomplished what could never be done over the phone.
Pierre (engineer) immediately took the RT for a ride to get a personal feel the bike's behavior on the road, in turns, braking, etc. They pulled a front shock and subjected it to testing and measurement. BTW, mine has a 300 lb spring. They then ran these measurements, along with bike weights through their software to calculate shock specs.
Recognizing the problem with an exposed lower shaft, they designed a shock with the shaft at the top. The final product was a dual rate spring (300 & 425) with a bridged reservoir at the bottom and with adjustable preload and rebound.
The shock was mocked up and installed to check clearances, ride height, bottoming, and to make sure I wouldn't run into any install problems.
As part of the process, it was found that the bike's pivot point is such that when my wife climbed on, the added weight transferred to the rear suspension and front ride height was unaffected.
So my shocks will be ready in a week or two (they were waiting on one of the two springs to come back from being coated). Will post pictures of shocks and install process.
The price point will be $1,105 for the pair. A less expensive solution could probably be available if one were to go with a single spring, etc. Ask for Tom Edison.
P.S. Lamonster - This Tapatalk app works great.
