Wheel is aligned! It took about another hour and a half of going back and forth but I finally have it done. One of the things I took note of this time is the outline of the plastic cap on the swing arm vs. where the center of the axle was. On the sprocket side, you could tell that the axle was well back of where it had been previously. To correct that, I loosened both sides by several turns and then used a wooden drift with a hammer to tap the axle forward on that side till it met resistance and then rinse and repeat till I had it roughly centered. I then tweaked the sprocket side adjuster by about a quarter turn to put some tension on the belt and then put a like amount on the other side as well.
I had ordered the Kriket belt tension gauge and it came in today. I checked the tension and it was too tight, about 200. So I backed each adjuster off a quarter turn on each side and used the drift again to move the axle forward. Finally I got the belt tension to about 160 or about a 90 degree turn in the middle with some resistance. Tightened the axle and torqued it to about 90 ft lbs. Took it for a short ride and checked it again, belt had shifted slightly to the middle. I'll put it on the jack again tomorrow and tweak it a bit more, but I think its pretty much done.
Lessons learned: Stop when you are tired or things dont seem to be going right. A day or two in-between did a lot to refocus and see the problems from a different perspective. Second: Nothing is easy the first time. Were I to do this job over, I could probably do it in a couple of hours instead of a couple of days. But you just dont know, what you dont know and as much as you can watch videos and read online, many times it comes to trial and error. :hun:
