ok im confooosed...i have an se5 and all i have to do to get from first to neutral is hit the downshift(-) button once.....I then asked him how do I properly get the machine from 1st to N,, he told me that the "best to his knowledge is that you hit the minus button",, we all know now thats incorrect,,
:banghead: OK, I got a bit curious and started doing some digging. The following blue text is copied from the 2009 Spyder GS owners manual online at the factory site.
page 12
4) Gearshift Lever (SM5 Model)
The gearshift lever is in front of the left
footrest.
The gear pattern is Reverse-1-Neutral-
2-3-4-5.
I can not find a straight forward gear pattern for the SE5. See the red text below.
page 13
To shift into neutral from first gear or
reverse, briefly press or pull the gear
selector. A longer activation will shift
over neutral. Refer to 7) SHIFTING
(p.55) for detailed instructions.
When the gearshift selector is released,
the mechanism resets for the
next shift up or down.
If operator does not downshift when
slowing down and engine rpm's drop
below a threshold value, the TCM will
automatically downshift gearbox to
the next available gear.
The TCM also automatically shifts the
transmission into neutral if the vehicle
is started with transmission in gear.
page 56
7a) Practice Using the Gear Selector
at a Stop
First, while stopped, practice to single
shift between reverse, neutral and first
gear. Then practice to:
– Double shift from reverse to first
gear
– Double shift from first to reverse
gear
– Repeat until you are comfortable.
This indicates that the pattern is R-N-1-2-3-4-5.
So who has one that works and can tell us what it REALLY is?:dontknow:
Well folks, there ya have it.Well, here's the way mine works. When I come to a stop and want to put it in Neutral, I pull up on the shift bar (-). When I want reverse, I pull up on the shift bar (-) and while holding it, I push the reverse button. To get back into Neutral from reverse, I push the shift bar (+) one time. To get to 1st I push it twice. Each push or pull on the shift bar is done slowly and firmly. Neutral is not between any gear. It is the last gear on the negative push. You cannot get to neutral except from a negative push from first after a complete stop or a positive push if you are in reverse. I can start the engine if it is still in 1st gear, but the foot brake MUST be applied. When that happens the transmission goes to neutral when the engine starts.
this is exactly how my 08 se5 worksThis indicates that the pattern is R-N-1-2-3-4-5.
:agree: (good thing bone crusher didn't give his advice)![]()
To all THANKS A BUNCH here... I took my spyder out the other day (jsut haven't had much time to update you) and practiced (1st to N) and my end result is just like yours Dudley,, I found out that using the (+) button does not work however--- Mike is correct that the book does say this statement:
selector.
Now if you are using the press method I believe they are telling you the (+) button right? Now if you use the pull method I believe they are telling you the (-) which is the correct one and the one that works for both me and dudley.. Just a light (almost 1/2 in tap) is what I found out will put you in (N).. Now Dudley let me ask you this.. Lets say you are in Reverse and you backed out of your driveway ready to go down the road,, You had mentioned your push the (+) button twice,, You do not need to do that,, all you need to do if you want to move forward is HOLD the (+) and it will go straight to 1st gear in order for you to take off--or move forward, now if you are parking it yes, just hit the (+) one time as you stated.. I ended up watching the vedio the other day and it mentioned that, so I thought that was cool,, and yes I practiced this as well,, works really good... Again, Mike Thanks and Dudley you as well but it appears that MY SHIFTING problem has been solved.. Now your method in getting the machine in (R) is tne (-) button then the (R) button,,, I would have to watch the vedio again but I believe it tells you to HOLD the (R) button then tap the (-) button.. I am going to look at the vedio again tomorrow, but if you find the correct method please let me know, I do know that using both methods it will go to reverse however, what is the correct method?
Chears.
Joe
