Spyder_Cowgirl
GOS member (Girls On Spyders)
Greetings all .... getting ready to install the Integrated HMT (the new High Mount brake light that also has turn signals built into it). :helpsmilie::helpsmilie: The instructions at this location: http://www.customdynamics.com/can_a...m#Street_Magic_Genesis_LED_RT_HMT_Brake_Light
... say that the connector harness has five wires, but the harness I was sent only has three. After talking with tech support at Custom Dynamics, I now understand why ... the Spyder is wired in such a way that the turn pulses are sent uniquely to each of the individual tail lights. So, if the Integrated HMT is wired into the right tail light connector, then only the right turn signal works on the unit. Thus, their instructions have changed, as follows:
I've done the "dis-assembly" portion of the install -- trunk lid, back panel, back fascia, and have loosened both tail lights to have easy access to all connectors. Of course this is a holiday weekend and I didn't think to ask the following questions of Custom Dynamics tech support.
This is all pretty spooky for me ... first time I've really taken anything apart on the :spyder2:. Since it is almost "plug-n-play" I think I can handle the electrical side pretty well, just need to confirm the correct / best location to tap the wires.
Advice from "our panel of experts" appreciated .... Thanks Much .... Ann
- Go ahead and plug the harness "in between" the two halves of the right side tail light connector (could just as well be left, but the wires from the HMT come down the right side of the trunk).
- Wire in the dual converter so the unit functions as both brake and running.
- Connect the three wires from the harness pigtail to wires from the HMT -- black to black, red to red, and orange to orange; this enables the middle section of the HMT (brake and running). All connections at this point are with posi-locks.
- For the right turn signal, locate the brown wire from the HMT and use a posi-tap connection to the brown wire on the RIGHT turn signal connector.
- For the left turn signal, locate the purple wire from the HMT and use a posi-tap connection to the purple wire on the LEFT turn signal connector
- For steps 4 and 5, where I posi-tap into the correctly colored wire, on which side of the Spyder harness do I tap in (the "bike" side or the "light" side)? :hun:
- Does it make a difference which side is tapped?
- I plan to protect the wires with shrink tubing where they pass through holes or might otherwise get chafed. Should I do something to protect the "posi" connectors as well? If so, what would you recommend?
