wireing
mtbear
Anyone know where I can run my neg. wires for my battery tender and heated vest?
Thanks.
mtbear:sour:
One option
attachment.php
Thanks.
mtbear:sour:
What ever you do DON'T use the neg. post under the seat, Or you'll posting how in the world do i get that bolt tight again.
Didn't you just get an RT? You can plug the Battery Tender into the accessory plug in the top trunk...
The heated vest; out of my league... :opps:
battery neg.
my battery tender pigtail is straight to the battery. i would do the same with heated gear.:thumbup:
tender hook up
I use the same connection made under the seat for both the battery tender and the gerbings heated clothing thermastat.:spyder2:
I drilled a small hole in the metal frame near the positive terminal under the seat and attached the Gerbing negative with a screw.
Took a male Gerbing plug and wired it onto a batt tender so I could plug it directly into the above during the winter.
Thanks
Thanks to everyone for the advice.
I figured it out.
Will be taking my Spyder in for 600 mile svc and trailer wireing Friday. Wish me luck.
mtbear
