WINTER WORK
JIM EVANS
well over the winter had the 2014 torn down and did some work
taller and wider w.s show chrome
pass armrests show chrome
chrome w.s. garnish can am
300 purple led's hooked to key fob controller light, strobe and face
electroluminescent wire to light antennas
saddlebag side markers show chrome
cb installed still cant find the damn drives cb harmess plug taking to dealer Monday morn
all dash parts and intake grilles painted plum crazy purple
all black body parts on body an mirrors painted to match the bike
only thing left to do is figure out what graphics and pinstriping... then get the brushes out and get that done
:f_spider:
attachment.php
attachment.php
attachment.php
more pics
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
in the dark
Awesome..!!
love the all white and know you will come up with some cool graphics...:2thumbs: great job, congrats...now go out and enjoy it cause winter is done..!! :thumbup:
I know ive seen it here before but ic you could tell me which white paint matches id precciate it!
Looks great... you must look up and find Sue Hopper to for the graphics. She is just awesome check her out on Facebook.
I do all my paint, lighting, wiring, etc myself :) just have to stare at the bike long enough till something pops to me.. i will probably change it three times before i end up with the finished product :banghead:
as for the color,, can am does not publish paint codes ,, but colorrite www.colorrite.com i believe does sell the paint in spray can or by the can with clear and solvents. I have access to a body shop paint mixing system so got about 20 pearl white chips got the closest one and tinted a bit and came up with a pretty close match.
all the work is in the prep in sanding out some of the texture of the black panels then the expoy primer then sanding again and then painting :)
PAINT MATCH
I did my Dash surround using Dupli-color Toyota White Pearl .......It has the metallic base in the paint which is translucent.......You will need to use a plastic paint primer first......( I recommend a very light gray if you changing black to white ) .....The translucent paint, because of it's make-up does not cover well , hence the light base coat........I think it was $ 9.50 per 12 oz. spray can...................Mike :thumbup:
PAINT SCRAPES
Thank you for input!
Have a few scrapes to deal with
OK, I thought you were going to paint an entirely separate panel .....like the rear black piece or the dash surround etc.........for doing very small touch-ups I would get something from color-rite or another seller that is actual BRP paint......a paint stick etc. from them is not a big expense and you would be happier...Good Luck ......Mike :thumbup:
