Left mirror, left deflector, left access panel, left middle side panel (oil check panel, left upper middle panel, left rear side panel, battery access panel. There may be a way to bend the panels enough to remove the battery access panel without doing this, but I wouldn't want to risk it. BTW, you will also have to unfasten the seat gas shock or use a small ratchet or plain torx wrench to access the rear battery panel screw. You can buy an adapter from the battery tender (SAE) to a cigarette socket, and just plug into the trunk outlet.
