windshield scatches
meguires motorcycle plastic polisher
[TABLE="align: left"]
[TR]
[TD][/TD]
[/TR]
[TR]
[TD][/TD]
[/TR]
[/TABLE]
Make clear plastics clear again!
Restore clear plastics with Meguiars Motorcycle Plastic Polish. Cutting-edge advancements in micro-abrasive technology gently remove fine scratches, surface stains, contaminants and light oxidation. Polish motorcycle windscreens and helmet visors to a like-new clarity! Water-resistant polymers provide long-lasting protection.
Over time, plastics become oxidized as a result of UV exposure. The only way to restore cloudy plastics is to polish away the oxidized layer. Clear plastic will show any fine scratches, so Meguiars formulated a clear plastic polish with micro-abrasives. Meguiars Motorcycle Plastic Cleaner/Polish polishes without scratching, leaving clear plastics clear again!
Meguiars Motorcycle Plastic Cleaner/Polish also removes ground-in dirt and discoloration that contributes to the cloudy, yellow look of aged plastic. In just one step, this plastic cleaner and polish clarifies plastic to improve its appearance and your visibility.
Vital conditioning oils restore optical clarity, while highly water-resistant polymers provide long-lasting durable protection. Your motorcycle's windscreen, helmet visor, and plastic instrument panels will stay clearer longer.
Meguiars Motorcycle Plastic Cleaner/Polish is designed for uncoated plastics. Apply the plastic polish with a foam applicator. Rub thoroughly onto one section at a time. Wipe off residue with a clean microfiber towel.
Restore optical clarity to clear plastics with fast and effective Meguiars Motorcycle Plastic Cleaner/Polish.
6 oz.
After you get the scratches out, here are some tips to avoid future problems:
1. Avoid wiping the windshield with a dry cloth. Even a microtowel can trap dust particles and scratch a widshield.
2. Don't use harsh chemicals to clean the windshield. Windex with ammonia, Rain-X, and other such products will soften and craze the plastic in time. Windex Multi-Surface with vinegar works well, as does a tablespoon of white vinegar in a gallon of water.
3. When it comes to cleaning windshields, the more water the better. A wet towel can soak off bugs before a good water cleaning.
4. Don't use waxes or polishes on the windshield, including Pledge. The white residue makes even the tiniest scratches seem huge.
5. Use products made specifically for plastics for best results Novus,Plexus, etc.). Don't use the abrasive (heavy duty) versions of these products unless absolutely necessary. They remove the hard surface layer, making it easier to scratch the windshield in the future.
6. Don't power buff a windshield unless youa re experienced in plastic polishing, have low speed equipment, and have the right buffs and polishes. You can destroy a windshield faster than you can blink.
7. Don't use a cover without a windshield protector. If your cover has no built-in soft protector, you can sew a protective sack out of sweatshirt fleece. Make sure the protector is clean and free from debris before use.
8. Don't clean or wipe your windshield in a circular motion. Circular scratches are more visible. Fore & aft scratches seem to hide the best.
