Windshield attachment
big dawg
2014 RT, is anyone having problems with the frame that holds the windshield? On my RT the screws for the T barrel which is made of brass, screws shear off.:(:banghead:
I just had mine apart a few days ago and didn't see any issues. Do you raise/lower your windshield a lot? I keep mine in the down position at all times, except to raise it when I wash the RT. I can tell you it's a very, very tight fit. In fact, using a Dremel, I reamed out all three holes just a bit, so I could get the brass barrels to slide back in without having to be forced. I understand the need for zero tolerance on clearance, but they should not have made them to have to be hammered back in. I can see where that would cause issues, which is why I corrected mine.
I know Bif Dawg hasn't replied yet, but I was driving 45 mph and the windscreen dropped with a major thud as the bolt in the center location fell out. A real eye opener at a nice rate of speed when you don't see anything but the screen drop and flop back and forth in the wind.
What sort of shape are your roads in? :dontknow: After having the center strut on mine bust after hitting a MAGNUM-CALIBER pothole :shocked:; I've decided to keep the screen "just off" of the stops at the bottom of it's travel. There have been quite a few reports of that strut breaking... I'm hoping that leaving a little bit of "wiggle-room" will prevent problems. :thumbup:
I've heard about that work-aound, but I don't want to have to remember to never leave the windshield at the bottom; also, I like the wind in my face as much as possible. I figure if it breaks, then it'll be replaced by my 2+2 warranty, then I can engage BRP as to a real issue; as I don't even use the up/down feature when I'm on the road. I only use it sometimes when I wash the RT, if I can't reach a certain area I need to get to.
The only problem with your I'll replace it if it breaks theory is what happens when it breaks while you are on a trip? Mine did that 3 days into a 6 week long trip. Duct tape and bungee cords kept it from flopping around for two weeks until I could get to a dealer to have it replaced. It looked like crap and wasn't very effective. Since then I keep mine about 1/2" up from the bottom.
I did have one screw head shear off, but that was when I was dismantling it for installing the tri axis handle bars. I have not had one do that from riding.
