Will Saddlemen EX2200 fit the F3-S?
DrJohn
For long trips, which won't happen until spring, I want to get some kind of tour pack. I'm looking at the Saddlemen EX2200 mounted on the back of the backrest, not on the seat. Does anyone know if it will fit? Any other suggestions?
John
attachment.php
attachment.php
I have a Saddlemen BR3400 tail bag that I used on my trip to Ohio last summer. Holds a lot and sits very stable just tied down. I now have backrest and it has a wide band that will fit over the backrest for extra stability. In this picture it is empty so it looks like it is sagging but it also works well as a backrest.
attachment.php
Thanks - the saddlebags are actually off of the HD V-rod that I traded in for the F3. The mounting holes were just a little off from the mounting positions on the F3, but Lamont in his normal genius put together a set of mounting brackets for it when I picked it up last May. The bags are hard, locking, non-leaking saddlebags. They are discontinued as they fit the original v-rod with the narrow rear tire but you can find a set every so often on E-bay. I was very glad that Lamont could do this, he was a life-saver!
No, wish I could but I store my helmet in the frunk. They aren't the biggest but they were cheap (free) and functional!😎 They don't add much extra weight to the bike either. It is surprising how much I can stuff into them, tho
Hi,
Are these the same as your saddlebags?
http://www.ebay.com/itm/V-rod-saddl...eec9ebda8:g:T0AAAOSw~OVWukk8&vxp=mtr#viTabs_0
BR3400
I also have the Saddleman BR 3400 for my 2015 F3. I have it tied down on the passenger seat and use it as a backrest (lumbar support).
the tail bag has double zippers and I drilled larger holes in the zipper pulls so I could pass a small cable lock through them and lock the contents. I also pass the cable lock through the grab handles to secure the bag. Marginal safety, but better than nothing.
The empty bag does hold a full face helmet and holds its shape even when I lean on it.
Highly recommend it
Yup! I was just going to post that. The holes for the mounting brackets on the inside of the bags are about an inch closer together than the holes for the grab rails on the F3. I measured the distance on an F3 at a dealership before I bought the F3. Then Lamont did the rest when I brought the v-Rod when I traded the bikes. That was just awesome the way he hooked them up!�� I love my Saddleman BR 3400 too!
