Pastapower
I have a 2013 RTL that I purchased from a lady back in May who bought it new & only put 975 miles on it since June of 2013.
When I drove it to it's new home from San Diego to Palm Springs, the bike shuttered & vibrated almost uncontrollably at times, all above 45+ mph. I haven't been on a bike in a very long time & never a Can Am, so I didn't quite know what to think.
I did all my vetting homework on the bike before purchasing it, calling the service dept where she bought it & asking questions about the 600 mile checkup, ect.
They said everything was perfect.
I have since adjusted the tire pressure, put on the BajaRon sway bar & Heim links & Smooth Spyder belt tensioner. I even put the Counteract balancing beads in all tires as well.
With all that, the vibration & drifting dropped in half & felt like a diff bike altogether.
I have also adjusted the belt alignment & tension close to the new BRP's specs (630 +/- 100 nm)
Now my vibration is pretty much only at 53-55mph, but still annoying & unacceptable to me for a "new" bike that cost $30K when originally purchased.
Originally, Tightning the belt tension more through the adjusters or smooth Spyder made it worse. I have the smooth Spyder adjusted at 11 right now.
The belt alignment when I first bought the bike had absolutely no gap at the sprocket flange, zero....& the tension was at 200lbs tire on the ground (Criket II). I loosen it to 170-180lbs on ground/160up. But, damn it, still have vibration!
When I brought the bike in to my local Can Am dealer to have the air scoops & heat management kit put on for the 2013 recall, the tech did a complete checkup & said he had to adjust the steering through the on board computer, but other than that, everything looked excellent. Mind you, he never drove it. I asked him about laser alignment & he said it wasn't necessary & not to get caught up on all the hipe on it. Of course, they didn't offer it at this dealer (Malcom Smith).
Could it be that the bike sat more than being ridden and caused "flat spots" in the Kenda's??
I don't see or feel any flat spots and it runs true down the hwy w/out pulling left or right.
Short of getting a laser alignment, Elka shocks & or new front tires, I am absolutely stumped.
Anyone out there have any suggestions or is the more than normal vibration at double nickel hwy speed normal for a Spyder. I have read every single post/threads on this to no avail.
BTW, this is my first Spyder purchase.
Anybody know of someone in the SoCal area of Komifornia that does Laser alignment?? Maybe that's all she needs right now.
Any help would be very much appreciated.
Clint
Clint
