safecracker
Well-known member
Went for a ride on Thursday night and we where hearing a noise coming from the right side of the bike. At first I thought is was the front wheel bearing. Friday I did some investigating and the front wheel bearing was ok. Removed the side panels and lifted rear wheel off of the ground. Had bike in 1st gear and I found my problem. It is a $18.00 part that could mean tha t we may be going to the Spyder Anniversary by car. It is the main PTO bearing. Engine has to come out and the crankcase split in order to change this bearing. Dealer has the bike, but no bearings. Bearings won't arrive until Thursday. Dealer and I looked a the BEST warranty coverage, it is covered, yipee. So They will need to order alot of parts, gaskets, exhaust bushings, seals, oil change, anti-freeze change, clutch fliud, etc. Book says 8..4 hours for repairs, I don't think so, I think a good 2.5 days. Dealer has been very good to deal with. Final note, thank God for the BEST warrenty that I purchased. Warranty runs out in August.... Spyder is a 2011 RTS, SM5, 48,000 miles.
