Why won't my zumo 660 come thru the speakers?
jetmechoh
I have a 2015 RT Limited that came with the Zumo GPS. When I use it I get no sound out of the speakers on the bike. I've got the picture and directions on the screen but no sound anywhere. I must have a setting wrong somewhere. Any help would be greatly appreciated.
i have a RT 2015. I think mine is a 595? But if anybody added a different one like 660, have to look and see if connections right side, beside gas tank ( you will have to take off that side panel) to see if the audio plug is plugged in. Or maybe a setting on GPS. Would help if you had manual for it, or download one. Thats only info I can provide, maybe someone else??
Can you hear sound with unit off the bike just changing voices? Would check the volume on unit itself & on bike multiple setting can conflict:gaah:
First thing I would check is to make sure it's not muted.
Or to make sure the volume is not turned down low.
A few things to check.
Did it work previously and has now failed ? Or has it never worked?
Is the GPS plugged into the audio system. There is a male plug on the GPS harness that needs to be plugged into a female connection on the bike harness. This connection is, unfortunately, buried inside the body work.
Is the GPS set to motorcycle mode ? If not, the external speaker connection is disabled.
Are the verbal instructions muted ? Or the volume is set too low ?
Keep us posted.
