So my belt was riding against the rear sproket flange so I thought I should adjust it. Must have tried 10 times now. it's either over the edge or right on the edge or against the flange. Went for about an hrs. ride and it was right on the outer edge so I thought I will just do 1/8 turn and it still goes right up against the flange.
I wouldn't stress about getting it tracking
EXACTLY right too much!! :lecturef_smilie:
These belts move around
A WHOLE LOT as you ride forwards; then they'll move even more if you back up even just a small part of just foot or so!! :banghead: Which basically means that it'll change & move back & forth somewhat during riding even if you have it looking perfect
RIGHT NOW after aligning it while your Spyder is stopped & sitting without a load on it, instead of while it's moving along at varying speeds on an uneven surface with the suspension articulating up & down under a load that moves & changes, so much so that even just a small
PART of one turn of the front sprocket will probably change were it
appears to be spending most of its time on the rear sprocket as you ride along!! And who's to say that your rear sprocket is mounted
exactly square to the rim or to the rotation of the wheel assembly anyway - most aren't!!
Besides, you do realise that these rear sprockets on our Spyders are a 'press fit' into rubbery 'cush pads' that have a fair whack of inherent movement and shock absorbing capability built into them anyway, don't you?? :dontknow:
So the reality of your 'accurate belt alignment' & 'true belt tracking' is that no matter how 'correct' you might THINK you've got your belt aligned while you're not on it & riding; no matter how perfect it might look at any given moment, even while you are riding; it's probably not 'running true' in that spot and only that spot as you ride and there's even a couple of vids floating around showing this really is what TRULY happens as you ride, but it's FAAARR MORE LIKELY to be wandering a little (or a lottle
) back and forth across the teeth on that rear sprocket pretty much all the time you're riding, and yet it's STILL DOING ITS JOB PERFECTLY WELL!! :thumbup:
All if which means that if you can see while your Spyder is stopped or just gently rolling the rear wheel forwards that you've got your belt aligned
fairly close to the flange on the wheel side of the sprocket, maybe even just touching it a bit just so long as it's not actively riding up onto that flange, then the alignment is probably
AS GOOD AS IT'S EVER TRULY GOING TO GET, cos the second you start moving & riding it & making it do all those things & more that've been mentioned above,
IT'S GOING TO START MOVING & TRACKING BACK & FORTH ACROSS THE SPROCKET ANYWAY!! :gaah:
You can't stop it from doing that; the factory can't stop it from doing that; the dealer (
ANY dealer!) can't stop it from doing that - it's simply the nature of the design & the limitations of the engineering.... altho some unscrupulous dealers/techs might try to convince you otherwise in order to milk more $$ from you!
Sure, you can aim to get close to the specified alignment; you can even have a few tries at getting it to be reasonably close to that; but don't waste your time, effort, &/or $$ trying to get it to be EXACTLY PERFECTLY THAT, cos the reality is that just so long as your Spyder's belt is closer to the flange side than it is to the outer edge of the sprocket; so long as it's not hanging a significant part of any teeth off the outer edge of the sprocket; so long as it's not pressing so hard up against the flange that it's burning the inner edge of the belt &/or riding teeth up onto the flange, then it's going to do its job fine and you shouldn't stress or worry too much about getting it any more accurately aligned,
cos the second you start riding again, THAT BELT ALIGNMENT GOES OUT THE DOOR AS THE BELT MOVES AROUND ON THE SPROCKET WHILE YOU RIDE!! :lecturef_smilie:
And
THAT brings us back to.... can you guess?? :dontknow:
Yeah, I'm gonna.....
I really am gonna say it
again.....
You've gotta learn to RIDE MORE, WORRY LESS!!
hyea:
Besides, chasing the perfect but impossible to achieve 'true & unwavering alignment' of your Spyder's drive belt when there are so many variables that cause it to constantly change really defeats the entire purpose of owning and riding these things!! :yikes:
