Why change the sway bar?
I can only speak for meself, but I drove 1000 kms with the original spyder, then I put on a sway bar, I immediately noticed the difference in handling, then I upgraded the front tyres after 2000 km's , and the rear shock, we drive alot 2 up, and the original shock, was just too soft, Placed a Fox RC, adjustable one, changed the preload on the o.e.m. front foxshocks, not quite happy with those, but I am pondering on new springs from MTTV. Still have the o.e.m. kenda (almost 10.000KM's) on the spyder, but this is going to be refitted with a Hankook RS4 225/45R15 soon
All in all it's personal, if you are a cruiser, the spyder is more than capable, If you really want to drive the spyder, you need upgrades.
I drive spirited, not quite like martin the vlogger does, but close... ghegheghe, and when cruising with the missus, she will knock the helmet when I go too fast (and this happens...)
I bought a used 2013 STS last year. It did handle strangely in corners. Put the Baja Ron sway bar on and it made a world of difference. Handles much better in corners. Well worth the expense for me. Luckily I had an area service guy from the dealer who did private work on the side on his days off. An hour at his house and it was done. He made it look easy but had done them before and had the right lift to get it high enough to change out the bar.
I just had a Baja Ron sway bar put on today. Its not going to make a fair rider a great rider. What it does is smooth out the front suspension. Your ride is smoother especially in the corners. Highly recommended
