Why Change OEM Heim Joints?
ulflyer
What does the metal ones offer that the OEM doesn't?
I seldom have read of Heim joint failures, so why change?
Is it mainly peace of mind?
Peace of mind, and I've seen people post pics of broken ones.
I didn't want one breaking and having to make it back home w the swaybar bashing around underneath on the way back.
There has been some reports of broken OEM joints. I did it just because it makes sense when putting a beefier Bajaron bar, to also have beefier Heim joints. JMHO. :doorag:
As I see it..!!
Security. There were some and I stress some that were faulty. Those were replaced with a better one. Now if you add the BajaRon sway bar you are increasing the tension and I would recommend the metal him joints. If not your fine with the updated composite ones..!! :thumbup:
Hi Gene,
Re: Now if you add the BajaRon sway bar you are increasing the tension and I would recommend the metal him joints.
Sort of depends on what you are riding. I asked Ron via email about Heim joints for my '08 and he said that I do not need them.
I went with his sway bar only.
Jerry Baumchen
Whats a him joint? :popcorn:
Dont answer that lol
If you're just adding the end links; it's more for piece of mind... and knowing that you've got the best parts on the bike! :thumbup:
If you're adding a stiffer anti-swaybar; it should be considered as a necessary addition. :clap:
Had not heard about composite ones. What models have these?
