Who invented Sea foam and Lithium Grease?? Wonderful stuff...
Tierhog
Alright who invented these wonderful products? Some Seafoam in the tank, Lithium grease on the clutch lever, brake pedal assembly/linkage, and ohhh myyy the gift shift lever. Wow. This 08 feels like a 12! A must do!
I use Sea Foam occasionally and use Star Tron the rest of the time...it's cheaper. Both are great products.
Seafoam
What is Seafoam, what does it do and where do I get it?
Seafoam is a gas treatment that had been used in boats, cars, and trucks since before WWII.
http://www.seafoamsales.com/
It stabilizes fuel, cleans injectors, etc. I use it in all my vehicles every 10k. Two cans plenty for 2 cars and the Spyder. Cleans egr, PVC, vacuum lines beautifully.
Good product.
I don't add to crankcase though.. Don't want to mix with Amsoil. It goes in the tank :)
Seafoam
Good product.
Thanks. I'll check it out.
Lithium grease is fine. I only use seafoam or stabil for stabilizing fuel. Never for cleaning injectors. There is no way to tell what it does or is doing other than SOTP feeling or "I experienced no problems". For injector work, I take them out in the winter and send them off for testing. For $15 per injector, I get to see what the fuel has been like around here to the injectors, verify that they are working right and know the spray pattern and volume are what they should be. I do this ever few years with all my powersports stuff.
On my Vette, I had 8 injectors that were not doing the same thing. Car felt right to anyone including myself. Sent them out and one of them had a big drop in fuel volume because of a collapsed basket filter and the rest were somewhat closer. After the treatment, all were flowing at the right rate within 2 tenths of each other. There is KNOWING and there is GUESSING.
