Who Has Installed These Running Lights on their Spyder?
Mounted my D2 Driving lights on My 2015 RT . I mounted the driving lights on the plastic A-Arm cover. I did not drill through A-Arm nor did I remove the plastic cover.
I drilled through the plastic a-Arm covers and used very large washers to spread out the pressure of the bolts on the A-arm cover.
attachment.php
Don't they a lot when riding due to the natural up and down movment of the A-arm? I tought about doing that but i figured they would move and shake too much, if they don't i will do it!! i like the set up!
You will have to make some supports depending on where you want to mount them. Some go for the A arms but there is a lot of movement there...Here's what i
I did.... Did have to put a backing plate cause it is all pastic but they have worked well for four years now....:thumbup:
attachment.php
On both s
ides with the switches on the bars
attachment.php
This is on an RS....
Where did you find the switches? need to buy some for the Spyder and my other bikes:)
Got then online funny named place for electric stuff will see if I can find the name but Google handlebar switches they will pop up....
easternbeaver.com is where I got them...told you it was a funny name for an electic company....:roflblack::roflblack:
Ha ha, that is where i bought the switch bypass for ,y Rocket, thanks for the info, will get on it right away!:thumbup:
