StSpyder09
hyea:Went out on only my second ryde and am getting to know RD fairly well. There is a whining noise coming from the back. Thanks to you all, I'm pretty sure its my belt, which is too close, and is rubbing against the sprocket internal flange. I haven't purchased a service manual yet, so I'm not sure where to start making the adjustments. Has anyone posted a video of the adjustment process?:helpsmilie:
If your belt is rubbing the flange it will whine, I keep my belt a little less than an 1/8 inch off the flange, that stopped most of the whining.
You'll need a 36 mm socket. If you go to search you'll find detailed info on how to adjusted it.
But maybe you should bring it back to the dealer it should not have the left the dealer with the belt against the flange.
ive had that nosie ever since i got my spyder 4 months ago and i dont think you can get red of it a spyder thc,.road my spyder to my house 45 miles and took my triumph back i traded and he told me it was good to go.its a 10 rm rs.so i not woring about it .i hope thats the case.:dontknow:
[/QUOTE]Write me to my email address and I'll send you back information on how to center the belt on the rear sprocket of your Spyder. Best you align it well because the repalcement belt costs about $10.00 I think. [email protected], Arthur---Mexico City
One of the first things that should be done in this situation is to have the dealer adjust the belt to the new, much lower tension spec. If you have over 6,000 miles on the Spyder, the front sprocket bolt should be loosened and retorqued, too, if it hasn't already. These are service bulletin items that are essential to prolong life of the bearings and keep the belt tracking properly. A "whine" from the rear bothers me! Even when it was running hard enough against the sprocket flange to leave marks, Nancy's Spyder did not make noise. I think you need to check your wheel and sprocket bearings for damage...or just replace them. The rear bearings on the Spyder are a known weakness. The belt alignment can be adjusted when these other things are done.
[/QUOTE]:gaah:Write me to my email address and I'll send you back information on how to center the belt on the rear sprocket of your Spyder. Best you align it well because the repalcement belt costs about $10.00 I think. [email protected], Arthur---Mexico City
Are you sure that your passenger is happy? :roflblack: :roflblack: :shemademe_smilie:ray:
I'm not going to post what my wife said... However it concerns noise from the rear :roflblack::roflblack::roflblack:
