Which Vredestein tire sizes for 2015 RTS?
9CLOUDED
Ive searched the forum and see multiple answers.
I have a 2015 RTS, just bought new vredestein quatros.
Front- 165/60/15 and rear 205/50/15 due to recommendations here. Having regrets with that rear tire being too small, should I go with a different size? 205/60 or 215/60?
Have yet to find a shop near me (Oregon Coast) to mount the tires let alone install them still. I'm thinking I will need to do this myself.
Thanks in advance!
Thanks in advance!
The only 50 series Quatrac's I see are both " 195 " width .... you could use the 205/60-15 or a 205/65-15 ..... Most tire shops can mount & spin balance the fronts if you bring the tire and wheel in ..... the rear you'll have to do yourself .... lots of Video's on U-tube ..... Mike :thumbup:
Ah, thanks. That was miscommunication on my end. I did get the 205/60/15. The can am dealership by me would not mount/spin or touch the tires at all without them being Kenda. I will try a local tire shop.
Any thoughts on the 60 vs the 65?
60 vs. 65 ???? .... the difference is 5mm .....One inch = 25.4mm .... need I say more ???? ..... Mike :thumbup:
As long as you are satisfied with the narrower tire. You'll be fine with the 60 series.
This is correct ..... however it's almost meaning-less due to the fact that Spyders have VSS (ie. tracrion control ) .... When I put Toyo 185/50-15's on my RT they provided a hugh boost in traction ... annnnnnnnnnd the Nanny wasn't happy about it. ... Mike :thumbup:
