I have the Tricled 360 - got them from Slingmods. I like that that put out two distinctly different high-low beams that go where I want. I bought them thinking they'd be better than the two sided and I believe they are. I can't speak for the two sided LEDs since I haven't experienced them in my Spyder.
After watching both videos, I find your comments rather interesting. Headlight Revolution (HR) seems to not like any of the 360° bulbs, although they did not test the TricLED 360. Watching what was presented in the HR video, I would not install any of those in any of my vehicles, either.
I have installed the LaMonster bulbs in my wife's headlights and fog lights. While they are definitely brighter, I would like to have seen a different pattern for the high beam. As it is, the shutter simply uncovers a little more light that shines a bit higher. There is nothing that projects any farther down the road, it just lights up the trees a bit better.
Go for the best night vision you can get. Having a brighter bulb that wastes the additional light all over the place where you don't need it, or don't want it, is not the best choice. Putting less light exactly where you want it can be a much better way to go.
I think this is exactly what Wmoater is trying to do, but, like so many others, appears to be confused by all the "we're the best" claims by virtually every manufacturer. After trying a few other LED replacement bulbs in other vehicles and seeing NO improvement, it is nice to see someone like HR come along with their comparisons. Yeah, their recommendations are not cheap, but I have gotten to the stage where I would rather 'buy once, cry once' and not have to worry about my choice.
On a side note: I have a new (to me) vehicle that I would like to upgrade the lights to LEDs. I have a mix of projector low beams and reflector high beams, so it was good to see how differently some of the bulbs worked in the different housings. I also have the added complication that my DRLs are the high beams on lower power. So far, I have only seen one bulb (Morimoto 2-Stroke 3.0) that has a less-intense output for the DRL function, just like stock halogens. Again, not cheap, but if it works, ... GREAT. :thumbup:
